Headers?
Old Apr 17, 2016 | 05:10 PM
T9ja's Avatar
2005 E55 amg
Headers?
Just replaced my Top speed LT headers for EC Mid length Headers b'cos it leaks a lot. Kept the 400 cels Mid pipe cat. Went to the track and ran the car, and could not get my 60' down below 2.0. Top end speed is great. Trapping between 28-30mph on the 2nd half of the 1/8 mile. Question is, What could cause the sudden loss of my 60'. Normally, I get between 1.7-1.9 60'. Seems I lost low end torque.
Old Apr 18, 2016 | 07:43 AM
2000UZJ's Avatar
E55
Did you get the car tuned for the change? If not, it may take a few hundred miles to adjust for the new restriction/flow.
Old Apr 18, 2016 | 08:19 AM
sexyxe's Avatar
04 E55
A lot of people run faster than that stock. I'd say maybe you are also making a change to your driving style.
Old Apr 18, 2016 | 01:11 PM
Ls1toAMG's Avatar
2004 E55.98 SS Camaro.Jetta TDI. Expedition
Really shouldn't have made much of a difference. May have been one of those days at the track.
Old Apr 18, 2016 | 02:16 PM
T9ja's Avatar
2005 E55 amg
Check engine light came up today. Pulling P0432 and P0422 codes. Will getting rid of the cats fix this codes, or deleting the secondary o2 sensors?
Old May 2, 2016 | 09:15 AM
T9ja's Avatar
2005 E55 amg
Help needed. Driving back home, my car went dead on me. Won't start. Pulled code p0335. Try to restart the car, but no success. Does this have anything to do with the sensor? If so, how do you replace it?
Old May 2, 2016 | 09:30 AM
2000UZJ's Avatar
E55
A quick google shows that code is related to CPS. Does it start when cold?
Old May 2, 2016 | 09:36 AM
T9ja's Avatar
2005 E55 amg
Never had a problem starting the car until now.
Old May 2, 2016 | 09:43 AM
2000UZJ's Avatar
E55
CPS will show no symptoms until it does. It either works or it does not work. When the car heats up the sensor will loose connectivity and the car can't figure out where the crank shaft is and can't adjust properly so it shuts the engine off immediately. It should be able to crank once it cools down but will shut back off when it heats up again. It's a common problem and pretty easy to fix
Old May 2, 2016 | 09:47 AM
T9ja's Avatar
2005 E55 amg
Thanks. So do need to replace the sensor?
Old May 2, 2016 | 10:10 AM
2000UZJ's Avatar
E55
Yes you do. Here is a great DIY article. I purchased mine from Amazon. It was 1/4th of the cost of the OEM.
https://mbworld.org/forums/w211-amg/...-diy-pics.html
Old May 2, 2016 | 11:54 AM
T9ja's Avatar
2005 E55 amg
Surely, the car started just fine again, but I'm getting it replaced right at this hour. Part only cost $64. Thanks.
Old May 2, 2016 | 12:23 PM
Hotsauce55's Avatar
2005 E55
Any difference between the LT's & the EC ML's?
Old May 2, 2016 | 01:57 PM
T9ja's Avatar
2005 E55 amg
My findings might not be ,too accurate due to the fact that, the LT headers had a leak. Main reason of making a switch. The car feels much responsive and faster now with the EC ML, compared to the time I had the leaky LT.
Old May 5, 2016 | 01:30 AM
T9ja's Avatar
2005 E55 amg
Got the car back and everything looks good, so far. Ended up returning the $64 part, and getting an updated version from the dealer for $184. That was even cheaper from where I got the $64 sensor. They were asking for $204 to get that same part #. All codes are gone for now.
Old May 5, 2016 | 11:59 AM
Rocman8's Avatar
E55
What's this new updated part # and what's the other one? Thanks.
Old May 5, 2016 | 05:20 PM
T9ja's Avatar
2005 E55 amg
The older part # ends in 2728, and the updated version ends in 2828. All other part #'s are the same. Just the last four digits have changed.
Old May 5, 2016 | 05:54 PM
Rocman8's Avatar
E55
http://www.amazon.com/gp/aw/d/B001CO...hiL&ref=plSrch
