Bosch 010 intercooler pump DIY
The following 6 users liked this post by Richardmozis:
alihou007 (04-27-2016),
chingwodapigu (04-29-2016),
compaddict (04-27-2016),
forcedawd (05-01-2016),
Justiso (05-10-2016),
and 1 others liked this post.
great DIY. question: is this strictly for replacement of a failing/failed pump? (I assume there is a symptom of a failed pump). Or is this a needed step for a modified engine?
The new pump has better flow thus better cooling. Helps eliminate heat soak after you run your car hard for a while. If you are going to modify your engine it's something you should definitely look into.
Richardmozis (04-28-2016)
