Billet idler pulley for less than 100$
Old Apr 27, 2016 | 01:40 PM
thb's Avatar
thb
None
You can purshase this :
http://www.ebay.com/itm/03-04-Cobra-...lWIBuU&vxp=mtr
A cobra idler pulley will fit with some grinding at the back of the pulley, it took me about 10 minutes to fit by removing some material, even the center bolt and cap is bolt-on !!!
bearing is a 6203
Old Apr 27, 2016 | 02:34 PM
2000UZJ's Avatar
E55
I have been thinking about ordering all new pulleys and having them powdercoated. Call me crazy, but I haven't spent any time in the engine bay. I may snag that as it looks nice!
Old Apr 27, 2016 | 03:36 PM
latemodel21's Avatar
2003 SL55 / 2002 SLK32
These Metro Motorsports pulleys are top knotch.
I have been working with this company for years as they supply the pulleys for the M112K Belt Wrap Kit that I created and sell. Great stuff (and most everything is available in a double-bearing version).
here are some of there other pulleys that I have been using from them (below)
Cheers,
Chris
Attached Thumbnails Billet idler pulley for less than 100$-img_20130422_200613_843num.jpg
Old Apr 27, 2016 | 09:29 PM
menace2sobriety's Avatar
2004 E55 AMG
bearing is a 6203
Good find
So what part of the pulley did you have to shave metal off?
The outer ring or where the bearing butts up to the assembly, and how much needed to be removed?
Old Apr 27, 2016 | 10:20 PM
thb's Avatar
thb
None
as i said, it took about 10 minutes to remove materiel with cutting wheel. after this mod, the part is bolt - on.
Old Apr 28, 2016 | 03:26 AM
BBBSS's Avatar
03 E55 AMG, 06 Harley Road King Custom 06 Ram 2500 Cummins, 97 Firebird Race Car, 88 Cutlass Supreme
Sounds like we need to get the manufacturer to this thread as they can easily modify these properly to work with our setup and they'd sell probably as many or more than they do to the 03/04 Cobra crowd.
Old Apr 28, 2016 | 05:21 AM
turbo97se's Avatar
05 E55 AMG, E320 CDI, Turbo E46 M3,IS300 2JZGTE,VQ35 Turbo Maxima, Mercedes 300D
I was going to say the same thing ... if they shaved off the material, it would allow for a lighter pulley overall as well as being useable on E55 and Cobras. Not to sound negative to OP, but I don't like to remove material on rotating masses personally unless it is chucked up and lathed properly. I am just **** that way ... but that is a great find.
Old Apr 28, 2016 | 10:33 AM
BagMan's Avatar
E55, E320 CDI , CLA250, Jag XJ Supersport
Cheers,
Chris
Nice setup Chris.
Do you happen to know the specs of the bolts on your belt wrap kit?
Mine have allen heads and it sucks for belt changes.
Old Apr 28, 2016 | 02:34 PM
JoeNobody's Avatar
Mercedes
Ideally replace the idler with a larger pulley wheel, then it would negate some of the need for a belt wrap kit.
Old Apr 28, 2016 | 04:32 PM
Originally Posted by BagMan
Nice setup Chris.
Those pictured are 8.8 (more than adequate considering their size and double shear mounting arrangement) . I actually like allen drive bolts better (for the look). With a properly created set-up, belt changes should be so infrequent as make head type a non-issue.
If you are looking to change yours out, however, Mcmaster Carr has a good selection with grades up to 12.9
http://www.mcmaster.com/#standard-cap-screws/=126kj19
I like the flange head cap screws for applications like this as well.
http://www.mcmaster.com/#standard-cap-screws/=126kj8t
Cheers,
Chris
Old Apr 29, 2016 | 08:59 AM
BagMan's Avatar
Cheers,
Chris
Sorry Chris, I should have been more clear. I'm looking for the thread, pitch and length of the bolts if you happen to know it. It would save me from pulling them out again to measure.
Old Apr 29, 2016 | 10:08 AM
mkiv_tdi's Avatar
Jetta TDI [Daily] , Audi A8L [Sold], '12 STI [Sold], '06 E55 [Sold], '05 S500, '15 GLA250
Someone should def get in touch with the manufacturer. Looks like it won't take them much more to knock down those areas to make it work for us and have no impact on the cobra guys. And that way everything is balanced and not 'handmade' with a dremel (not a knock on you, OP. Good find!!)
Options are good, is all I'm saying.
Old Apr 29, 2016 | 10:13 AM
hayseed's Avatar
04 e55
2 bearings make it nice heavy duty setup
Old Apr 29, 2016 | 10:53 AM
The kit was for a M112k (AMG 3.2 V6) so the bolt sizes wont be the same as your E55 uses.
Chris
Old Apr 29, 2016 | 11:14 AM
I have worked directly with this manufacturer, Metco (over the last 3 years). Their product and commitment to quality is beyond compare.
I have had them make 4 different custom pulleys for Kits I have designed and sold ... but they have gotten so busy with their cobra stuff that they stopped scheduling custom builds.
You can try contacting Rick Bejarano (co-owner, head of sales at Metco), but you would probably have better luck getting ASP https://www.autospecialties.com/ to make a double bearing version of their 90mm idler (that they already make for this Mercedes application).
My $ .02
Chris
