Oil used by the dealer today?
Old Apr 27, 2016 | 08:41 PM
june82000's Avatar
'05 E55
I didn't think about it and my wife was the one who took the car in but when I looked at the paperwork when I got home I noticed the dealer used MB oil instead of Mobil 1.
000-989-83-01-USB9; 5w40 is what was used.
Is this the same as Mobil 1 or should I call them about it?
Old Apr 27, 2016 | 09:17 PM
RZT5's Avatar
Edition 507 Coupe, M278 powered E550 Coupe, S211 E500
I do not believe this is Mobil 1 since the 5W-40 version of Mobil 1 is a 229.51 oil, not a 229.5 as listed.
This is a good thing, as you DO NOT want to use a 229.51 oil for gasoline engines, let alone AMG engines. 229.5 is the appropriate spec for the motor in your car, and this is genuine MB fluid after all, so I think you can rest assured that it's the right stuff!
Old Apr 27, 2016 | 09:23 PM
1970gsx's Avatar
'06 E55
Is that $214 for labor for an oil change?
Old Apr 27, 2016 | 09:36 PM
june82000's Avatar
'05 E55
I guess I need to do some reading. Did they change the recommendation at some point?
Old Apr 27, 2016 | 09:41 PM
june82000's Avatar
'05 E55
Essentially yes, but is is the labor charge for the Service 'A'. They wanted to charge over 3k for things they say need to be fixed.
Old Apr 27, 2016 | 10:54 PM
RZT5's Avatar
229.5 has always been the recommended spec for gasoline engines. For a brief period, MB told dealers that they could use 229.51 in gasoline engines so that they only had to stock one type of oil that worked in both diesel and gas engines. Every dealer seemed to get this notice, but few of them seemed to have read the notice sent out at a later date saying to stop using 229.51 oil in gasoline powered cars because it was causing problems. Your dealership seems to be the exception since they put the right stuff in!
Old Apr 27, 2016 | 11:01 PM
thtguy's Avatar
2017 GLS 550
They also charged for a drain plug ring. I have yet to see a dealer drain oil. They always suck it out.
Old Apr 28, 2016 | 04:11 AM
sexyxe's Avatar
04 E55
$690 for valve cover gaskets! Holy smokes Batman!
Old Apr 28, 2016 | 12:20 PM
FLE55AMG's Avatar
2006 AMG E55
151 for air filters? does that come with the reach around
Old Apr 28, 2016 | 01:38 PM
djempirE55's Avatar
E55, Granturismo, F430, 993, E39, Jag
You're good.
