Stalling after cold start
Old May 2, 2016 | 03:40 PM
Dato55's Avatar
2005 e55
Hi, I have a 2005 e55, this morning I went to go start my car and it started up but was idling rough and then stalled, after it stalled I tried starting it and fired right up like normal, car has 70k and crankshaft sensor was changed at 59k, any ideas as to what is causing the stalling?
Old May 2, 2016 | 08:37 PM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
moved to W211 AMG forum...
Old May 2, 2016 | 10:35 PM
Rocman8's Avatar
E55
Check for fault codes and start with monitoring fuel pressure.
Old May 2, 2016 | 10:37 PM
Dato55's Avatar
2005 e55
It threw no codes
Old May 5, 2016 | 02:51 AM
bmwm3turbo's Avatar
e55-03 , m3 e36 irs drag car
same as mine
i always come around it this way
turn igniton on 3sec -turn off ,and then start (im guessing loosing fuelpressure when it sitts still is my problem)
iff do not do it that way my car throws mappsensor code at coold startup, and going ultra lean
these cars are so sensitive
this problem came whith 550cc inj and 82mm tb, didnt have it whith stock injectors and tb
Old May 5, 2016 | 10:19 AM
djempirE55's Avatar
E55, Granturismo, F430, 993, E39, Jag
Check SAI plumbing....could be a leaking.
Old May 5, 2016 | 10:45 AM
bmwm3turbo's Avatar
yes that could be your problem
dont have secondaary air injection on my car
Old May 5, 2016 | 10:58 AM
Dato55's Avatar
2005 e55
Mine is completely stock and it hesitates on startup sometimes but has only stalled once so far and what's the SAI plumbing?
Old May 5, 2016 | 11:11 AM
djempirE55's Avatar
See attached picture of the Emission/SAI System...
Description: essentially dumps air to your cats for a brief period until they get to "operating temp". If any of the emission hoses are leaking, clogged and/or the shut off valves are faulty, you will get exactly what you described @ startup. This issue is associated with a P0410 code.
Old May 5, 2016 | 11:38 AM
Dato55's Avatar
2005 e55
I'm off this weekend so I guess ik what I will be doing, plus just in case I got new plugs and wires and air filter to see if that helps
Old May 5, 2016 | 11:55 AM
Rocman8's Avatar
E55
I'm curious as to how in any way the secondary air injection system could cause rough idle or stalling.
Old May 5, 2016 | 12:14 PM
Dato55's Avatar
2005 e55
Im just doing that cause filters were dirty, I'm hoping plugs help it because it has stock plugs at 70k
Old May 5, 2016 | 12:18 PM
djempirE55's Avatar
Think of the motor is one giant air pump. The ECU tasks the emission components to pump more air so the cats/O2's heat up quicker; at the same time extra fuel is added adaptively to the calculated fuel quantity to run the motor smoothly. If you have a leak and/or the valves are faulty your motor will stumble/misfire due to the factors mentioned above.
Old May 5, 2016 | 12:27 PM
Dato55's Avatar
2005 e55
I will have a detailed look over this weekend to see if I find anything, if I can't find it then I will bring it to my mechanic
Old May 5, 2016 | 02:15 PM
Rocman8's Avatar
E55
Secondary air is only injected into the exhaust stream not through the engine so it will not make the engine run any differently. The engine module does not add more fuel when secondary air injection is active since there is no point as the extra air is only in the exhaust and not in the engine. Watch AFR when sai is active and you'll see its very lean. The only possible way for this system to affect driveability is if one of the diverted valves doesnt close completely and would create a vacuum leak but there would be other issues as well.
Old May 6, 2016 | 09:10 PM
chawkins2001's Avatar
2006 E55 AMG
Originally Posted by Dato55
It threw no codes
Your fuel pumps are failing if it threw no codes and stalled.
Old May 6, 2016 | 09:21 PM
Dato55's Avatar
2005 e55
Pump
Is there anyway I can check to see if the pumps are failing?
Old May 6, 2016 | 10:00 PM
Rocman8's Avatar
E55
Yes. I said start by monitoring fuel pressure.
Old May 6, 2016 | 10:31 PM
Dato55's Avatar
2005 e55
What can I buy or do to monitor fuel pressure?
Old May 6, 2016 | 10:46 PM
Rocman8's Avatar
E55
You can buy a fuel pressure tester. OTC is a common quality tester.
Old May 6, 2016 | 10:50 PM
Dato55's Avatar
2005 e55
Thanks I will look into buying this
Old May 8, 2016 | 06:25 PM
SICAMG's Avatar
2005 e55 AMG
I run a very small Dyno tune square fuel pressure,AFR gauge, an Apexi memory boost gauge and instant read air temp gauge. To me these are the most important and really give you instant answers when having a problem and I can see every thing at a glance.Great to have in any E55.
Old May 8, 2016 | 06:29 PM
Dato55's Avatar
2005 e55
Yes I want all of those and I want to start monitoring IAT's
Old May 8, 2016 | 07:11 PM
Rocman8's Avatar
E55
Don't forget to monitor timing as well.
Old May 8, 2016 | 07:32 PM
Dato55's Avatar
2005 e55
Is there anything I can buy that I can just plug into obdII port so I can monitor everything at once?
