How do you replace the upper control arm?
http://www.mercedesmedic.com/diy-how...m-e-cls-class/
Very easy just screw the three bolts on top and the lower bolt in on the bottom. Don't forget to use loctite.
Use a ball joint separator instead of a pickle fork. Also probably better to take off the tire and check your other joints to see what else may need to be changed.
and these cars are sometimes challenging to work on. My suggestion would be to separate the upper control arm ball joint and wiggle the control arm by hand. If it squeaks than it is the upper control arm bushing and if you can't remove it spray it with some grease/motorcycle chain lube or something similar. If it is clunking or it feels like the bushing is shot than it needs to come out. Search the posts on front end clunking and there are some long discussions on this with grease options. If there is no noise i would change out the ball joint. Gjunion has it pictured above, 3 bolts on the end of the upper control arm and off it goes. Install a new one (with loctite as suggested) and at least that can be eliminated from the list of possible problems. Harbor freight has a front end kit that has all of the tools you need to separate the ball joint and reassemble. It is not the nice hardened steel separator he has in the picture but it will work a few times before it yields...step by step you can make progress here. Good luck.
