Anyone no what this noise is ?
Car has been running good for years nothing but oil/trans fluid changes and tires
this noise has appeared. Car still seems to be running fine intermittently comes and goes u will hear best when car stunts off
Sounds like your ABS pump is on the way out. Normal failure item on the w211, it's called SBC or something to that effect, it pressurizes the reservoir and makes sure you have brake pressure all the time. In your case i'm surprised you don't have a brake warning light on, it sounds like it's not holding pressure and causing the pump to run constantly.
2006 E55, 2006 saab 93 aero, 2010 glk 4m
That sound is coming from the auxiliary water pump. It sits just behind the passenger headlamp and pumps coolant from the radiator into the heater core for the climate control. In the video its what you see at the 34s mark with the wire harness plugging into it. You can see the hose running by the sbc. Touch the hose or pump when you hear the noise next time to confirm its that as the vibration will match the sound.
