helpppp plzzz stereo!.
Old Aug 11, 2016 | 02:07 PM
Atk_gaming's Avatar
2005 e55 amg, 2005 audi s4, 2000 audi a4 1.8T (big turbo)
Originally Posted by Masri87
where'd you get the harness
What harness are you referring to? I actually made everything my self i dint buy any adapters.
Old Aug 17, 2016 | 02:10 PM
Atk_gaming's Avatar
Update:
SO i dint like my setup the new sub was expensive and all but its just not doing it for me as well as the full range speakers they are a little on the low sensitivity side so i decide to change everything again i have, i get very little bass and full range speakers don't work for my music at all.
New setup as follows:
-Kicker solo baric L7 15"
-sealed 2.6 cft
-6.5" HERtz high energy full range speakers x4
everything else will remain the same for now, will post pics when everything gets here.
Old Aug 17, 2016 | 02:52 PM
hachiroku's Avatar
SPONSOR
2007 Mercedes E63 AMG
might need a DSP to do EQ and time adjustment per channel, but if the speakers aren't doing their job, they're not doing their job. keep us updated!
__________________
-BARRY
​​​Follow us on instagram @eightysixtuned
https://www.eightysixtuned.com
Old Aug 17, 2016 | 03:06 PM
Atk_gaming's Avatar
I was considering the dsp but my clarion vx405 already has eq build in and filters i can use , the problem i had was the ds18 i bought are low sensitive so i gotta crank it up more to ge more sound plus i only put out 60rms and the ds18 are 120rms so i got lower rms speakers with slightly higher sensitivity so i wont need to crank itup so much just to get them loud.
Old Aug 17, 2016 | 03:47 PM
Skizz's Avatar
'20 GLE450; '06 CL65
Our cars are sealed up pretty tight from the trunk into the cabin. If you have a sub that isn't ported somehow into the cabin, you're gonna be fighting it unless you throw some power at it. I had a single shallow Hertz 10" with 400 watts going to it in a sealed enclosure in my spare wheel, not ported into the cabin, and it just could not cut it. Quite disappointing. I went with two major 10"s (Elemental Designs), sealed, and fed them with over 1k watts but did not port into cabin as I didn't want to alter rear deck. Also wanted to stay with smaller, faster subs, so decided to stick with 10's. Bangs like hell. So, even though I didn't port into cabin, the quality and quantity of driver and power going to them made the difference. It just takes both to get through the solid build of our cars. Of course, YMMV.
Old Aug 17, 2016 | 03:57 PM
Atk_gaming's Avatar
Everything is ok in my setup but the sub i got only does great with weak *** rap hip hop etc unfortunately i listen to death metal rock etc.
My old sub re.3 sound stream played hard but it fried this new sub im running atm is more rap hip hop bassy oriented so it sounds weak with my music unless i play rap dubstep etc then yea ground shaking.
Finally i when to a shop and try a 15" kicker l7 solo and it hit perfectly all notes so i got online and bought that instead gonna see how it does whe i installed it.
Old Aug 17, 2016 | 05:15 PM
  #32
hachiroku's Avatar
SPONSOR
solo baric 15"!!!!!!
you want them to hear you in Australia!?!?!
__________________
-BARRY
Old Aug 17, 2016 | 06:12 PM
  #33
Atk_gaming's Avatar
Lol no nothing like that, dont be fooled those subs only get loud with ported box sealed they hit clean
Old Aug 18, 2016 | 09:39 PM
  #34
forcefed4door's Avatar
05 E55, 06 Audi S4
It converts the fiber optic to rca. They sell it on eBay.
I really do think the stock system sounds pretty good in this car, I've gone every route with many different cars. I've grown out of the trunk rattling bass thing. Running wires everywhere installing adaptors to get aftermarket speakers to fit... all that stuff. These are real solid air tight cars. The stock head unit really holds it back.
Old Aug 19, 2016 | 01:20 AM
  #35
BoostedAero's Avatar
2004 E55
Hate to pester,but Ebay is a gross pool of Chinese crap that needs to be RMA'd regarding their car electronic adapters.
If yours works, I would like to use the same seller. Would you mind?
Old Aug 19, 2016 | 06:00 AM
  #36
05 E55, 06 Audi S4
http://m.ebay.com/itm/MERCEDES-E-Cla...wAAOSwARZXmcag
https://navtv.com/products/NTV-KIT00...s.html/gallery
Old Aug 23, 2016 | 04:12 AM
  #37
Atk_gaming's Avatar
Update
Ok so i got some of the stuff in just waiting on the sub.
Hertz 6.5 bc quality is everything on a benz.
Old Aug 24, 2016 | 06:33 PM
  #38
TheTherapist's Avatar
2004 W211 E55 AMG >>gone but not forgotten > W123 280E > W124 E280 > W126 380SE
Subd to see results....
Old Aug 25, 2016 | 04:05 AM
  #39
Atk_gaming's Avatar
The goods
The goods are here.
Le sub
Mounting the goods.
Old Aug 26, 2016 | 12:04 AM
  #40
Atk_gaming's Avatar
Installed
Sounds clean asf im finally happy and there is no rattle does not suffucate my mids and highs and ppl compliment me everywhere of how clean the SQ is.
Old Aug 27, 2016 | 07:26 AM
  #41
My impression is that you obviously have a good ear for audio so having said that I have a couple of questions about your install - and I congratulate you for your tenacity with getting this up to a standard you're happy with.
1. You have the sub mounted in the "well" of the trunk - are you honestly happy with the bass SP level that travels through to the cabin? Do you know offhand how many DB are being lost in travel. My experience (in various Mercs over the years) has been that the build quality, reserve tank and chassis structure has inhibited the transfer of bass frequencies (from trunk to cabin) to the extent I have ultimately put the sub in the center of the rear seat. I lose seating for one but gain a permanent armrest for the remaining 2 rear passengers in addition to the sound having much more impact and precision. This has been a last resort after trying everything; including (in past cars) compromising the structural integrity of the chassis by cutting open the rear parcel shelf and replacing with acoustically transparent material.
2. Aside from the SPL is there any perceivable latency or deadening of bass frequencies. I'm unsure what genres you listen to but this would be more noticeable with some musical styles than others. Have you had the opportunity to audition your handiwork with a variety of genres?
Thanks for sharing your experience and again well done!
Old Aug 27, 2016 | 11:15 AM
  #42
2004 E55
Agreed! Thanks for sharing!!! First and foremost I am not at all tearing you down and I love what you are up to!!!!
I spent 2 years as an installer for a high end car av shop here in Charlotte working summers. Great OTJ training and knowledge base...
I agree with the lossss of SPL to the cabin unless you port that box and vent it into the cabin; from the size you have (1.2ft^3?) it appears to be a sealed box...?
I would love to see the SPL from in the closed trunk then another reading from inside the cabin...that would be great empirical evidence of the loss of SPL.
My guess is you are loosing 30dbs :-/
I do not want to move my 12w6 with 2 ohm load 600w rms load into the stock sub location and hack things up with my roto-zip :0 unless it is warranted.
Like this but more work bc the 12 requires more spaceand I would need to re-design a basket to go back to factory for when I get tired of the car (if that happens)
https://mbworld.org/forums/w211-amg/...ement-e55.html
But I will probably end up doing that due to what all have exp with the loss
Can you test SPL on the same track (trunk closed then cabin sealed with you and meter inside?) and report back. I need some SPL numbers to figure out a cost benefit ratio of if it is worth the my time investment to gut then reinstall :-?
Something like this would give a ballpark for comparison if you cannot go by a shop and get them to measure that sub gut punch:
https://itunes.apple.com/ca/app/deci...448155923?mt=8
What I do not want:
I am afraid to go to a 1ohm load or more due to rattles mcgee, I am trying to keep it classy WIP y'all
Unported into cabin = muddy unclear bass in the cabin IMHO
Kind regards,
Will
Old Aug 27, 2016 | 01:51 PM
  #43
Atk_gaming's Avatar
Good question however i have not messure or tested spl it has been all just by ear, the current setup i have is mainly for metal,death metal,nu metal rock etc.
The bass is really loud i mean sterring wheel bounces loud but it sounds clean no distortion no rattle from outside sounds even better.
Box is sealed 2.6 cu ft giving it 1200rms @1ohm with a RE-audio vls-1 1 band low frequency processor and that does the trick.
As far as the position of the sub idk just seems to work the best all i didwas remove the oem subwoofer basket and leave that open and well its loud does not feel like it affects it much unlesd i face the sub towards the inside of the cabin then i can tell is not a loud.
Old Aug 27, 2016 | 02:03 PM
  #44
2004 E55
Nuff said, my chest is vibrating in Charlotte NC lol!
I am not an has to hit this hard SPL # kinda guy.
If it sounds clean clear and loud, has some good response that is what I am the point IMHO
Old Aug 27, 2016 | 04:01 PM
  #45
Atk_gaming's Avatar
Lol yea my spl days are over i just need it to be clean and easy to unplug the sub to remove when i go to the track so far it works good plus i love that chest pounding bass thing goes loww gotta love them 15 inch subs.
Old Aug 30, 2016 | 01:50 AM
  #46
Thanks for the feedback, you certainly have got me thinking about the possibilities...
