Where is this leak coming from?? **PICTURES INSIDE**
Old 08-04-2016, 10:52 PM
CarbonHan's Avatar
E39 M5, E71 X6M, W211 E63 AMG, W218 CLS63 AMG
I've been hearing a weird sound coming from what seems like underneath my car so today I raised her up and this is what I found behind the driver side motor mount on the steering rack(?):
An esteemed mercedes tech i've consulted with made an educated guess after asking me certain questions that the fluid is hydraulic fluid from my motor mounts.
I smelled the fluid thats gathered in my splash guard and it smells like clutch fluid. I visually checked my motor mounts and they look collapsed but i don't really see fluid seeping from them.
Anybody have a similar experience that can chime in and hopefully confirm the motor mounts theory or point me in the right direction? Thank you!
Old 08-05-2016, 02:31 AM
55Jeff's Avatar
2006 cls 55 amg
Go on a dead road, Open your hood put the car in drive and hold the brake and rev to 2000 rpm, if the motor is hopping right out of the engine bay its your motor mounts.
CarbonHan (08-05-2016)
Old 08-05-2016, 03:25 AM
sexyxe's Avatar
04 E55
How is your power steering fluid? A little oil goes a long way in making a mess though.
Old 08-05-2016, 04:13 AM
CarbonHan's Avatar
I'll try that tmrw. I'm a little afraid though because what if its NOT the motor mounts and the fluid is leaking from somewhere else and me just driving it exacerbates the damage
Old 08-05-2016, 04:14 AM
CarbonHan's Avatar
I checked the reservoir and it looks like its topped off. Also the power steering fluid kind of smells like soy sauce.. the fluid on my splash guard smells like clutch fluid.
Old 08-05-2016, 10:25 AM
Dublinoh's Avatar
E63 AMG 2007
What do you mean when you say clutch fluid? Transmission fluid? I have an upper timing cover leak and have oil in the same area. Are you sure it isn't oil?
Old 08-05-2016, 12:40 PM
1ForcedBenz's Avatar
Benz
If your so worried simple solution spend some money and have it diagnosed. If your "worried" but to cheap to get it inspected then that's your prerogative.
Old 08-05-2016, 03:21 PM
CarbonHan's Avatar
I recently changed my clutch on my m5 and the clutch fluid I used to bleed it smells like what's on my splash guard. I'm not sure what transmission fluid smells like though so I guess I can't rule it out yet. I checked for oil leaks and didn't find any. I do believe my pcv is bad though and I have read that it would be leaking oil if it was. I'll check it out today and report back
Old 08-05-2016, 07:03 PM
JoeJErnst's Avatar
2019 Jeep Trackhawk, 2002 CLK55, 2014 911 Carrera
I think your esteemed Mercedes tech friend is right. Looks like a leaking motor mount.
CarbonHan (08-07-2016)
Old 08-05-2016, 08:37 PM
Rocman8's Avatar
E55
Thats way too much fluid to be from the motor mounts. The motor mounts did pop at some point either been repaired before or these ones popped. you can tell by the stain on the power steering rack but its all dried up and old looking.
Old 08-06-2016, 06:12 PM
gjunon's Avatar
04 E55 AMG
It will drive extremely rough if it's the mount. There is a video on YouTube somewhere that shows the test on a bad mount.
Old 08-06-2016, 06:24 PM
layzie12g's Avatar
2008 Mercedes Benz E63
It look like the rack itself is seeping. Clean the under tray with brake clean and the rack. Put it back on and then go drive it.
Old 08-07-2016, 04:40 AM
CarbonHan's Avatar
I took it in to have my transmission fluid changed and had my indy take a look.
Youre right on the money.
Looks like power steering fluid is leaking from the steering rack somewhere. It looks like its easy to drop the steering rack mount to look and find where its leaking from but i don't know how to keep the steering rack itself from falling on me when i do this.
Has this happened to you before? Or do you know where to look?
Old 08-07-2016, 04:43 AM
CarbonHan's Avatar
You are also correct. My driver side motor mount started leaking a little bit of fluid and the residue dried up on the steering rack. So now I need to change my motor mounts AND find/stop the leak somewhere on my steering rack
Old 08-07-2016, 08:12 AM
StarvingArtist's Avatar
CLS 55 AMG E500 99 ML320
There are O-rings were the power steering lines come in.
Old 08-27-2016, 03:09 PM
Preet's Avatar
E63 AMG W211 & W203 Sport Pkg
CarbonHan any update on where it is leaking from on the steering rack?
Old 08-28-2016, 03:36 AM
CarbonHan's Avatar
not yet. I've been driving the x6m a lot lately because i'm too lazy to get under the car and take the steering rack mount off. I'll probably get to it sometime this coming week.
Old 08-31-2016, 09:44 AM
Benztech858's Avatar
2004 E55 - 2010 GL450 - 2011 GL550
That fluid is definitely coming from the engine mounts.
Old 09-02-2016, 06:07 PM
CarbonHan's Avatar
Its a mixture of power steering fluid leaking from the power steering lines to the steering rack or possibly from the steering rack... AND motor mount fluid. I had the bad luck of both of these things happening at the same time...RIGHT after getting my headbolts, cams and lifters replaced.
Quick Reply: Where is this leak coming from?? **PICTURES INSIDE**
