Power steering reservoir o ring
Old Aug 15, 2016 | 07:52 AM
Hotsauce55's Avatar
2005 E55
Replacing the o ring between reservoir and pump. Is it as easy as 1 bolt and remove c clip then pull reservoir forward off the pump flange. Replace o ring and put back together? Then can I simply fill with fluid or is there a bleed procedure?
Old Aug 15, 2016 | 12:53 PM
Hotsauce55's Avatar
2005 E55
Awesome, thanks
