Redline vs LiquiMoly
Old Sep 22, 2016 | 04:58 AM
Windowguy's Avatar
2012 Audi S4 & 2008 E63 AMG
I just had an oil change done my E55 and I went with the Redline 5w40. Car felt like it was making more power but I am not sure if its from the oil change or the cooler temps or because of the new Bosch 010 pump. Oil was a lot more $ than the Mobile 1 I got on sale last week.
Rob.
Old Nov 19, 2018 | 08:41 AM
cfmistry's Avatar
15 S550 4Matic, 86 560SL
Wrong thread!
Old Apr 21, 2025 | 02:32 PM
lifeisamovie's Avatar
135i N54
Originally Posted by 951turbo
I'm a redline guy. It's a group five ester based oil, very stable and had low noack with a great HTHS 4.4 high temp high shear numbers on the 5-40 oil. Also high 176 vescosity index. Stay away from Mobil 1. It's Death in your motor! The redline is light years better than the liqui moly. I've been a tech for over 25 years on German cars and a big oil nerd. Hope that helps.
so is motul 300v better than redline or redline is still king? i heard of the ester core on 300v is quite nice and might be better
Old May 14, 2026 | 01:33 AM
FlyingJoint's Avatar
They are little different 300V is really designed for track use maximizing performance with very short drain interval around 3K KM because it don't have that much detergent as other oils
Redline are designed for longer OCI and better suitable for daily use compare to 300V.
if you don’t care about cost and the short OCI
go for the 300V
i do heard people mentioned that avoid using additives and fuel cleaner when using ester based oil that can cause sludge to build up.(I really don’t know personally)
Also ester works by creating a natural bond to metal it self so can conflict with how oil additives works.
Old May 14, 2026 | 01:51 PM
135i N54
oil choice
go for the 300V
so if im doing oil changes at 2000 or 1500. would redline be better for engine longevity or 300v? I just use my car to daily but jt has 17ts. 208k miles. I use redline 5w50 becuase 5w40 always came out like thin after drain. and 300v doesnt have 5w50 on fcp euro for me. the cleaner the engine to longer that head gasket stays good imo
Old May 14, 2026 | 01:58 PM
SICAMG's Avatar
2005 e55 AMG
Can't speak for 300V but have used Redline at every track event along with Mobil 1 normal driving and the bearings looked like they came out of the box brand new. The Redline for sure has better quality when talking with the reps at Redline and will have a higher thickness, "W" to it when hot according to their spread sheets on it.
