Suction Fan Problem - Help please
Old Oct 13, 2016 | 11:17 PM
Marsaydeez's Avatar
2008 E350
Exclamation Suction Fan Problem - Help please
What would cause the cooling fan that's attached to the radiator to run very fast and loud like a jet turbine immediately after starting the car with cold engine?
The connector plug on the fan has 4 pins :
1- 12v input
2- ground/chassis
3- control voltage from ECU
4- control voltage from SAM (sensor inputs from coolant temp, outside temp, refrigerant pressure.
I'm assuming it's either a sensor failed, or a faulty fan.
Thanks for the help!
Old Oct 13, 2016 | 11:18 PM
ItalianJoe1's Avatar
2003 CL 600
Could be a failing fan, or a working fan receiving a bad input causing it to run full speed on purpose.
Check actual values in SDS.
