E63 cluster swap Q
Old Dec 8, 2016 | 07:38 PM
spastik monkey's Avatar
Veteran: Army
Chevrolet Traverse, Honda Cbr1000RR
E63 cluster swap Q
so I swapped my cluster for an E63 cluster ($275 from LKQ). The cluster worked but had the ------- for mileage. I swapped the PCB, and everything works now, but I lost all of the cool e63 features (oil temp, lap time, ect). Is there a fix to resetting this pcb to work with mileage and the oil temp?
Old Dec 8, 2016 | 09:06 PM
Forrest Gump 9's Avatar
shrimp boat
Yeah, reset the odometer and reprogram the miles back on. Shardul can do it I think
Old Dec 8, 2016 | 09:35 PM
Veteran: Army
I may have to borrow a star and see if that fixes it
Old Dec 18, 2016 | 12:02 AM
Max.H's Avatar
E55
I got the pre safe warning after swapping to 63 cluster. Anyone get that with 63 cluster swap? Every function works perfect mileage too. I better remember to tell the guys to check it when it hooks up to star on monday.
Old Dec 18, 2016 | 03:03 AM
Veteran: Army
How did you get the mileage to appear correctly?
Old Dec 19, 2016 | 11:46 AM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
cluster must be new and requires version coding to transfer odometer to the new cluster...
Old Dec 20, 2016 | 05:14 PM
gts007's Avatar
06 E55 AMG, 86 Corolla,87 E30,02 LSB M3
I just swapped it and got the pre safe warning ..
Old Dec 20, 2016 | 05:19 PM
gts007's Avatar
did you get it fix yet max H.?
Old Dec 23, 2016 | 11:08 AM
Max.H's Avatar
E55
I sent my cluster to a friend and I got it back and mileage was working.
But, the pre safe stayed on. I had the car hooked up on star and the mb tech couldn't figure it out. He said there is no faults in the SRS system. I dunno. Can anyone chime in on how to fix the pre safe warning light?
Old Dec 25, 2016 | 03:41 PM
Veteran: Army
Update. I just ordered a star Scanner. Will be playing with changing adaptations and trying to remove presafe.
