Removing front sway bar for drag racing yea or no
Old Jan 27, 2017 | 03:12 PM
Samdog357's Avatar
E55 amg
Has anybody did this ... if so how much difference should i see
Old Jan 27, 2017 | 03:55 PM
99lightning's Avatar
99 ford lightning
it will make the front end come up alot easier and faster to transfer weight
Old Jan 27, 2017 | 03:59 PM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
You could just disconnect the end links rather than removing the whole sway bar.
Old Jan 27, 2017 | 05:04 PM
Samdog357's Avatar
E55 amg
ok i figured it. .. but has anyone tried it and seen whatkinda difference it made
Old Jan 27, 2017 | 05:07 PM
Samdog357's Avatar
E55 amg
cool understand that too ... have you tried it ... because i have put 2.82 gears out of a sl55 in mine and now i can't hook to save my life with Drag radial on cant get out the 2s 60ft smh
Old Jan 27, 2017 | 05:26 PM
Hulk's Avatar
A Merc
That has nothing to do with the 2.82 gear. How's the prep? What's the tire pressure? What kind of burnout are you doing etc.. Guys with 2.82 hook well also, it's all in the prep and the tire pressure
Old Jan 27, 2017 | 05:52 PM
Samdog357's Avatar
E55 amg
305 35-18 tires 22 lbs is this tires Mickey Thompson SS i tried all the way to 15lbs i tried dry hop and burn outs smh
Old Jan 27, 2017 | 05:59 PM
Hulk's Avatar
A Merc
255/50/16 Hoosier drag radial,this is the best setup bar none ,stay away from the qtp as it usually lowers mph but will hook pretty good
The ET street 265/40/18 work well also
Samdog357's Avatar
E55 amg
Old Jan 27, 2017 | 06:04 PM
Samdog357's Avatar
E55 amg
already had265 40 18 didn't work out. .. initial hook supercharged come inblows Away the tire
Hulk's Avatar
A Merc
Those won't work, not enough sidewall
Old Jan 27, 2017 | 06:06 PM
Samdog357's Avatar
E55 amg
do anyone have suspension work or are you doing the stock set up
Old Jan 27, 2017 | 06:07 PM
Hulk's Avatar
A Merc
Put the car in comfort and raise it, that's it
Old Jan 27, 2017 | 06:16 PM
Samdog357's Avatar
E55 amg
maybe something is wrong with my suspension I tried that too
Old Jan 27, 2017 | 06:18 PM
Samdog357's Avatar
E55 amg
175 best 60 foot before gear
Old Jan 27, 2017 | 06:20 PM
Hulk's Avatar
A Merc
It's your tires my friend you don't have enough sidewall. Don't y to reinvent the wheel(no pun intended lol) it's been proven time and time again . Consistent good 60' Hoosier drag radial 255/50/16 on clk rims
Old Jan 27, 2017 | 06:24 PM
Samdog357's Avatar
E55 amg
Cheater Hoosier slick CLK rims going to try
Old Jan 29, 2017 | 07:32 PM
Max.H's Avatar
E55
Are those the CLK63 Black series wheels? They are 18"? Look like 19s. Looks good.
Old Jan 29, 2017 | 08:06 PM
Samdog357's Avatar
E55 amg
Yes clk 63 they are 19s and thanks
