spinning noisy bearing noise at low speeds, when off the throttle? Is it driveshaft?
Old Mar 12, 2017 | 11:02 PM
Max.H's Avatar
E55
heard a spinning bearing sound only at very low speeds in a parking lot. When you push the gas then hit the brake it's like something spinning. Like a noisy bearing. Hard to describe but, its when you hit the gas then tap the brakes in a parking lot or coming into a garage and something just spins and it seems like it will keep spinning or making that noise until you stop the car tap the gas pedal again.
can not duplicate the sound when car is parked. Only when driving very slow speeds in parking lot.
I thought it could be the driveshaft bearing. Or is it supercharger bearing?
Been on a maintenance perfection binge. So, if anyone has encountered this let me know thanks!
Old Mar 13, 2017 | 04:03 PM
Max.H's Avatar
E55
Like a Spinning bearing sound. But, which one and how to diagnose it.
Old Mar 13, 2017 | 07:47 PM
dchl21's Avatar
Gallado Spyder / AMG C63S / Cayenne
my ic pump makes a sound. could it be your ic pump ?
Old Mar 13, 2017 | 08:06 PM
Max.H's Avatar
E55
No it's not the IC pump. It's something connected to the engine. That rotates with the engine or the transmission. I am thinking its a driveshaft bearing that is getting noisy.
I am sure someone has had to experience the same before.
Old Mar 15, 2017 | 10:08 PM
Max.H's Avatar
E55
Anyone?
Old Mar 15, 2017 | 10:25 PM
RBM113K's Avatar
03 E55
You could take serpentine belts off one at a time to rule out a bunch of rotational noises,then go from there ,just a suggestion
Old Mar 16, 2017 | 04:44 PM
Max.H's Avatar
E55
Does anyone know, if the inner supercharger bearing make noises when it goes out? My engine is mint, only has around 50k miles.
Old Mar 16, 2017 | 04:47 PM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
Check the torque converter
Old Mar 18, 2017 | 08:42 PM
Max.H's Avatar
E55
OK, What am I looking for? Thanks!
Old Mar 19, 2017 | 02:46 PM
equitiesguy's Avatar
Mercedes CLS 55 AMG
Sounds like the supercharger bearing to me, or one of the belt tensioners.
Old Mar 19, 2017 | 04:15 PM
Max.H's Avatar
E55
It is definetly something that can spin independently of the engine and belts. So, the torque converter might be or possibly SC bearing. I dunno. Because ai cant replicate the sound when car is stopped.
I'm on a keep the car in perfect working condition spree.
Old Mar 21, 2017 | 10:01 AM
ghlainez's Avatar
Veteran: Army
06 E55 AMG
Where is the noise coming from? I had a similar noise. I thought initially it was a bearing that had gone bad. The noise was coming from the left rear so I started to inspect and it turned out that my emergency break shoes had literarily disintegrated it was in pieces. so try and check that.
Old Mar 21, 2017 | 11:46 AM
Toadster's Avatar
2005 E55 AMG
Does it sound like this?
Old Mar 21, 2017 | 04:02 PM
Max.H's Avatar
E55
https://youtu.be/JdkKoHyHgk4
Mmm Kinda does. How do you fix that or is that even an issue.
That's an idea I can disconnect the SC belt and see if it still does it.
Old Mar 21, 2017 | 06:39 PM
FunkTron's Avatar
2006 CLS55
that's just the supercharger pulley bearing....
removing the belt and running the car would eliminate that noise (if that is the cause)
