4000lb Sideways
Old Aug 12, 2017 | 09:03 PM
  #226
jumph4x's Avatar
W210 DRFT BNZ
Welp, shop found the exhaust leak. It's at the collector side of the header flanges. Sigh.
Look like I'll be running the next event with a huge exhaust leak and then taking apart my exhaust system. Makes me wish there were CARB compliant headers on the market.
Old Aug 15, 2017 | 04:59 AM
  #227
jumph4x's Avatar
W210 DRFT BNZ
Dropped in the replacement sub, this thing only ran me $50m dual voice coil version. Any more powerful than this would require serious refactoring back there due to the rattling (read on). This required the usual: cutting out the middle metal panel, drilling mounting holes, extending the speaker wire, etc:
Getting rid of all the rattling back there is damn near impossible but a big source of it was the rear windshield curtain rightmost mounting bolt.
I doubt I *fixed* it but it seems to have improved. I undid the 4 bolts from the trunk side holding this entire bar in and stuffed some soft stuff under the left and rightmost mounting brackets. I used sound deadening cloth/fiber/matt that MB themselves use under the rear seats, just cut off small pieces.
As for the FMHE, I finalized the mounting today but cutting access ways in the bumper support to put the nut on the other side of the bolt (previously it was temporarily tapped into the aluminum bumper support itself).
The first hole I made was too big and I had to do extra work with that additional aluminum rib you see, separating it from the cutaway panel was annoying.
Here is the view of the bolt/nut from the side:
The entire bumper went on without any problems (after the plastic mounting bracket trimming I already outlined). Not entirely sure what people meant when they said there would be clearance issues.
Old Aug 18, 2017 | 04:36 AM
  #228
jumph4x's Avatar
W210 DRFT BNZ
The FMHE project is a success!
View this post on Instagram
Old Aug 18, 2017 | 07:52 AM
  #229
StarvingArtist's Avatar
CLS 55 AMG E500 ML320
Nice! Thanks for posting up video!
Old Aug 18, 2017 | 03:28 PM
  #230
tlambert's Avatar
2005 E55 AMG
That is some serious "smoking the tires".
Old Aug 18, 2017 | 09:41 PM
  #231
jumph4x's Avatar
W210 DRFT BNZ
Essentially a 3rd gear rolling burnout. This is what happens, haha.
Old Aug 21, 2017 | 09:09 PM
  #232
jumph4x's Avatar
W210 DRFT BNZ
September will be a VERY busy month:
- Looking to weld the differential and get rid of these asinine toe settings
- In talks with Eurocharged right now for a ECU/TCU/Pulley package, entertaining a custom TCU flag for actual gear-hold pending their engineer's review
- Some long overdue branding for the project, targeting rear quarterpanel/trunk/door area
- The damn headers
Old Sep 13, 2017 | 07:45 PM
  #233
jumph4x's Avatar
W210 DRFT BNZ
Hehe, drifting an E63S on MBWorld homepage right now
Old Sep 16, 2017 | 11:37 PM
  #234
jumph4x's Avatar
W210 DRFT BNZ
Eurocharged ECU and TCU tunes are in, but they experienced a supplier issue with the pulley, so that will be arriving late. However, going to test out the new camera setup tomorrow morning and grab some new footage, it's been a while!
Old Sep 17, 2017 | 12:31 PM
  #235
PJmak's Avatar
You gotta bring that thing to the amg private lounge at laguna seca on the 30th. Register deadline is by 22nd.
I think they let you slide on a cone course
Old Sep 17, 2017 | 03:51 PM
  #236
Strigoi's Avatar
2001 E320 Wagon, 2006 LBZ Silverado, 2007 E63 (sold), 2001 E55 (sold)
Last year you had to use their cars. You didn't get to take your own car on either course. It's also an autocross course, not for drifting.
Old Sep 17, 2017 | 08:06 PM
  #237
jumph4x's Avatar
W210 DRFT BNZ
That's a negative on all accounts. I'm registered but not 100% on the whole thing.
Old Sep 19, 2017 | 01:54 PM
  #238
jumph4x's Avatar
W210 DRFT BNZ
Getting excited, tomorrow will be a good time.
Going to be running three GoPros angles simultaneously.
Old Oct 7, 2017 | 07:58 PM
  #239
jumph4x's Avatar
W210 DRFT BNZ
EP4 around the corner. Wrapping up the cut.
Old Oct 11, 2017 | 08:12 PM
  #240
jumph4x's Avatar
W210 DRFT BNZ
Headers replaced, all new exhaust hardware, no more exhaust leak, sounds wonderful again.
Eurocharged 83mm pulley on, doesn't feel much different. Surprisingly, I had to remove all shims and I'm at the wide end of the gap spec on the clutch (0.35mm-0.45mm), engagement is noticeably smoother than then the factory pulley, had obvious wear marks on both surfaces, I gave it a very brief and light scuff.
All appears to be well, we can move onto other projects soon. Big ones:
  • Lincoln Locker differential
  • Branding the entire car
And some smaller ones in the meantime:
  • An aero piece here and there
  • Fixing that stupid drifter alignment, it's eating tire like crazy
  • Tuning audio: tweak crossover points, isolate and fix sailpanel rattles, re-wire speakers into parallel circuits
  • Making a mount for the old steering wheel buttons and creating an alternative CANBUS harness somewhere in the center console so I can navigate the cluster menus again.
  • Disabling the air suspension and telecom modules
  • Sourcing sun visors
Staying busy busy busy.
Old Nov 7, 2017 | 05:35 AM
  #241
jumph4x's Avatar
W210 DRFT BNZ
Tried to disable the airmatic and telecom warnings, failed at both. It would seem this is something that has to be done before they are removed from the car, not after. Ah well.
Old Nov 7, 2017 | 09:08 AM
  #242
BC928's Avatar
2006 E55, Various other German and ‘Murican
That does not seem like what others have said. Very concerning.
Old Nov 7, 2017 | 10:36 AM
  #243
JoeJErnst's Avatar
2019 Jeep Trackhawk, 2002 CLK55, 2014 911 Carrera
There are two place a in STAR that you need to disable airmatic. You are probably missing the one under the Instrument Cluster menu. I can dig up the exact menu path if you need it
Old Nov 7, 2017 | 05:59 PM
  #244
jumph4x's Avatar
W210 DRFT BNZ
That would help because I plan to rip into it and hook up the factory stereo and wire in the airmatic fuse again so I can do this, plus posting it in here won't hurt anything for helping others go through this. Thanks!
Old Nov 7, 2017 | 06:02 PM
  #245
JoeJErnst's Avatar
I just remembered I updated an old thread with the answer here: https://mbworld.org/forums/w211-amg/...ml#post7280749
Old Nov 7, 2017 | 06:09 PM
  #246
jumph4x's Avatar
W210 DRFT BNZ
This works, thank you holmes.
Old Nov 7, 2017 | 10:25 PM
  #247
jumph4x's Avatar
W210 DRFT BNZ
EP4:
Old Nov 8, 2017 | 02:52 AM
  #248
jumph4x's Avatar
W210 DRFT BNZ
If you guys want to come shoot ****, take photos, get in the video, watch cars go sideways and overall just have a grand time, come hang out with me during the Winter Jam at Sonoma Raceway.:
Just copped my ticket: facebook.com/events/2000715766863310/
Only $20 for non-drivers.
Old Nov 18, 2017 | 11:44 PM
  #249
jumph4x's Avatar
W210 DRFT BNZ
Six minutes of tire screech:
Old Nov 19, 2017 | 02:53 PM
  #250
Strigoi's Avatar
What's the piece of tape for on the wheel?
Going to try to make it to the event next month to check this **** out.
You have already rated this thread Rating: Thread Rating: 3 votes, 5.00 average.
