Coilover conversion complete, need to get rid of warning light
Everything was perfect, just need help trying to get rid of the warning light on the dash . I'm getting the "display malfunction". Also, after driving for a while my Traction and cruise control also get warnings, I'm assuming it's all related.
I've tried searching, but can't seem to find an answer. Can i just pull a specific fuse/relay and the warning will disappear? Or do I need to take it in and get the programming switched over from "airmatic" to "coils". How involved is that process?
Any help would be greatly appreciated.
TIA!
First, turn off airmatic for the car by following these menu items:
Control Units
Body
System Diagnosis
Control Unit Adaptations
Read Coding and Change if necessary
Programming of Vehicle Equipment
Set AIRMatic = NOT FITTED
Press F3 to save the change
Press F5 to send it to the car
Second, disable AIRMatic in the instrument cluster:
Control Units
Information and Communication
IC - Instrument Cluster
Control unit adaptations
Modification year or model year (not sure if this matters or how to know the right value; I guessed based on manufacture date of the car)
Variant Coding
Special Equipment (Wait a few seconds for all of the values to be read)
Set Partial air suspension to NOT PRESENT
F3 to save
That's it! No pulling fuses required and now you shouldn't see any warning messages.
Plan to track run it is the reason it is so low. But still rides great with the bcracing coilovers.
or I'm missing something ?
TIA!
Did you need any other parts for the conversion or just the coilovers alone
Second, disable AIRMatic in the instrument cluster, I can click all in green but when I get to the first red line (Modification year or model year....) doesn't show up. I have an E550 2007 W211.
Control Units
Variant Coding
F3 to save
Any ideas?
Control Units
Variant Coding
F3 to save
Any ideas?
Control Units
Variant Coding
F3 to save
Any ideas?
Control Units
Body
System Diagnosis
Control Units
Variant Coding
F3 to save
Now to find this for the W212
Probably the same or similar
