4000lb Sideways
Old May 2, 2018 | 05:34 PM
  #426
tlambert's Avatar
2005 E55 AMG
Nice dude! Getting s h i t done!
Old May 2, 2018 | 08:08 PM
  #427
jumph4x's Avatar
W210 DRFT BNZ
Voila.
Also below is the creative direction/branding I had a friend do for me.
Old May 5, 2018 | 03:55 PM
  #428
jumph4x's Avatar
W210 DRFT BNZ
ECE engine+transmission mounts are in, unbolting the steering rack is definitely the way to go on this task. Pretty low drama.
Thrust and front lower control arms are in.
This took some frustration and soul-searching but finally accepted I should do the job right, which involves taking off brake calipers, brake discs, unbolting dustshield, rotating it out of the way and using an actual tie-rod separator/puller to split the ball joints from the knuckle.
Installed external front bumper mounts, cut off factory internal ones.
Raised the rear a smidge.
Some more on thrust arms:
There are multiple bushing design versions available for these cars, I was sent the TRW units and I noticed the bushing is a lot sparser than what is presumably the Genuine versions (unverified). See photos below.
If I don't end up with spherical joint solid arms, I might have to redo this job in some years with the solid-fill variant.
On my car the first piece of suspension failure was the inboard lower control arm joint at the subframe, caused front wheels to toe out at speed and made straight tracking near-impossible.
Left side was easy to detect visually, but the right side would've fooled anybody unless they took a pry-bar to it. Check you car folks.
Old May 5, 2018 | 05:26 PM
  #429
FCPEuro's Avatar
Former Vendor of MBWorld
Mercedes
D and others interested in a more stout bushing in that tension arm. Substitute in bushing 2113331114, the Lemforder number is 2604301 and is that solid bushing that you typically see installed in the spring control arm on the 211/219. It is the best OE style bushing for the tension strut especially if you are really pushing the car. D, I'm going to send you a set of modified arms from syncrodesignworks that you can install on the car and hopefully provide some feedback here. We are talking about arms that take a half hour to replace at most so it wont be much trouble to swap them out again in a few weeks.
--Kyle
Old May 6, 2018 | 01:49 PM
  #430
jumph4x's Avatar
W210 DRFT BNZ
Front plate mount arrived, awaiting some LED resistors for the clear side markers. Getting ready to pad the rear sub and find a couple of rattles and button up the sailpanel.
Have new black suede sun visors, too. Car will be in a great place by the end of the week.
Old May 9, 2018 | 01:33 PM
  #431
jumph4x's Avatar
W210 DRFT BNZ
Sent the car to alignment again, told the shop to drill out the tabs in the rear LCAs as per JoeJErnst's suggestion in another thread.
Going to move 255 tires to the front and burn off 245 in the rear today at Sonoma Drift. Have 2x 265 waiting to go in the back. I think 265 on all four corners is where I will end up with this car.
Still waiting on some SMD LED resistors for the front of the car, should be here before the end of the week.
Old May 9, 2018 | 06:56 PM
  #432
Strigoi's Avatar
2001 E320 Wagon, 2006 LBZ Silverado, 2007 E63 (sold), 2001 E55 (sold)
Where are you having the alignment done? I need to have my E63 done but I'm not familiar with any good shops around here. I'd rather not go to the dealer.
Old May 10, 2018 | 01:43 AM
  #433
jumph4x's Avatar
W210 DRFT BNZ
I go to the place across the highway, they charge only $85.
Tak is a nice guy, owns the 190E 16V Cosworth.
Old May 10, 2018 | 02:17 AM
  #434
Strigoi's Avatar
I'll check them out. Thanks!
Old May 10, 2018 | 03:08 PM
  #435
jumph4x's Avatar
W210 DRFT BNZ
Not sure how low your car is, but if it's tucking tire, they won't take it.
Old May 10, 2018 | 07:58 PM
  #436
jumph4x's Avatar
W210 DRFT BNZ
Yesterday's shakedown post-alignment with ECE mounts.
I have to say, 40A durometer mounts are a motorsports application. They hold nice and firm, almost too firm. We're interfacing with ECE directly and as I put it, the mounts definitely added to the 'drift' but took away from 'dapper'.
Not an issue once the car is rolling but at idle, certain primary resonance points can definitely be felt.
They are working on a more compliant durometer rating insert package that I will be trying as soon as it's available.
Old May 10, 2018 | 08:03 PM
  #437
mondo's Avatar
Alfa Romeo Giulia Veloce
love the new plates
Old May 10, 2018 | 08:32 PM
  #438
jumph4x's Avatar
W210 DRFT BNZ
Me too, took forever, but glad that project is over with.
Car now sits on 255F/265R. LED resistors are here! Tomorrow's hitlist:
- wire in resistors, experiment with a couple versions of LEDs for front corners
- cover brake line-transmission tunnel entrance with black leather/suede
- lower the front a smidge and see about removing a tiny bit more metal
- wash car
- grab more photos
Protip: Tried installing a W219 sun visors - not a 100% fit. Different shape bumps into rear view mirror, doesn't fully close and doesn't slide-extend when using to the side. Stick to W211.
Old May 11, 2018 | 11:19 AM
  #439
PJmak's Avatar
Where do you get alignment done on a lowered AMG?
Old May 11, 2018 | 12:00 PM
  #440
Strigoi's Avatar
You just saved me a trip. It is tucking.
Old May 11, 2018 | 09:56 PM
  #441
jumph4x's Avatar
W210 DRFT BNZ
Front DRL and side-markers are converted to SMD LEDs, wired in 4 resistors. I'm not 100% on using these clamp style splicers, I'm skeptical about how permanent this solution is, but I suppose same as anything: deal with it when and if it becomes an issue. No error codes.
For side markers, I grabbed some cheap Depo clear lenses and spliced into the harness near the connector.
The resistors run hot so they need to be mounted to metal surfaces only.
On the right side I used the condenser mount frame, on the driver's side I put into the bracket that used to hold the Airmatic pump.
For the DRL bulbs, I tapped into the harness up near where it passes the strut mounts:
Here are the external bumper mount rivnuts:
Now the car got washed and I'm off to see if I can make a little boot to hide the brake line entrance to the center console.
AMG suspension design and geometry is identical to non-AMG W211, makes no difference.
My car is lowered but I am running flares, so I can take them off and bring the car to any shop that uses tire clamps. Non-issue.
Check out https://www.yelp.com/biz/auto-innovations-milpitas. They charge around $150 and use wheel clamps, will align cars that are tucking.
There is absolutely nothing to do in the area, so bring a book, a Kindle or a laptop.
Old May 12, 2018 | 03:46 AM
  #442
jumph4x's Avatar
W210 DRFT BNZ
The tunnel is covered up, my black leather ended up matching the car's shift boot, this is good for now.
I keep playing with various tire sizes. Currently the car is not happy because it can detect a different rolling diameter front-to-rear.
One thing is for sure, whether I end up using 265/255/245 width, I need to go to 35 profile on the next tire change.
Car is currently raked out, but what's next?
Old May 12, 2018 | 09:21 PM
  #443
sterz85's Avatar
w205 C43, 958.1 CTT
If you had to take a bumper off, how would you go about doing that?
Old May 13, 2018 | 05:30 PM
  #444
jumph4x's Avatar
W210 DRFT BNZ
Ive been having to do it quite a bit so I made the external holders. 6 allen head stainless bolts per side, 3 allen head bolts for the front of the flares and the factory 4 holding it to headlighta, bumper support.
Quicker than factory setup.
Old May 24, 2018 | 12:04 AM
  #445
jumph4x's Avatar
W210 DRFT BNZ
Off to some place far:
Thirsty car:
Long road ahead:
Old May 24, 2018 | 12:08 AM
  #446
jumph4x's Avatar
W210 DRFT BNZ
Somewhere on the east coast, near my final destination:
New tire sizes, new suspension height and valve settings:
Menacing clouds, nothing like California:
Pretty, old structures:
Derelict:
Do not enter.
Old May 24, 2018 | 12:14 AM
  #447
tw2's Avatar
tw2
Great photos, how do you prevent yourself from just flooring it down roads like the one above? I would get a ticket almost immediately if we had roads like that here.
Old May 24, 2018 | 12:25 AM
  #448
drothgeb's Avatar
Veteran: Navy
2005 E55
Looks like NV, we've got lots of rural area just like that
Old May 24, 2018 | 12:28 AM
  #449
Strigoi's Avatar
Based off a previous post of his asking about going faster than the 155 mph speed limiter I think he indulges a bit.
Old May 24, 2018 | 12:31 AM
  #450
Strigoi's Avatar
Long road ahead:
Is that 14 in Mojave area (Cantil/CA City)? If not, it looks very similar to down there.
You have already rated this thread Rating: Thread Rating: 3 votes, 5.00 average.
