4000lb Sideways
Living in Oakland and all, stereo that fit the dash perfectly and look OEM are an obvious winner for not wanting to replace glass down the road.
That and while it's not cheap, it's a whole lotta bang for the buck.
I've had stereo equipment stolen while in Oakland. Only took me once to learn my lesson and take subs & deck out of the truck when going to my buddy's place there. That was around 12 years ago and I still find a small piece of glass in it sometimes.
I'll make a little stupid video when I'm done with the install if you want to just hang and see what it's like. Or you can even come by and play with it eventually since you're not far.
You are going to want to flash a custom rom to speed it up a bit
MCU- MTCB
https://forum.xda-developers.com/sho....php?t=3246370
MCU- MTCD
https://forum.xda-developers.com/and...evice-t3385309
Use factory shifters from your wheel to avoid getting stuck in first. I am pretty sure when circuit is left open it just keeps downshifting
MCU- MTCB
MCU- MTCD
MTCB/MTCD refers to serial number? Model number? I'll skim through linked threads.
EDIT: Found my answer here: https://forum.xda-developers.com/and...-mtcd-t3371252. Looks like I will need MTCD.
The 'GS' compact marketing while not entire false isn't quite where I need it to be.
Some of the flange sides at the mounting surface will have to be machined down, giving us about 4mm from each side, for a total of ~1.5cm width reduction, since these will go right next to each other.
This is going to James along with the handbrake assembly ASA he is done with the hub adapter.
Meanwhile, it looks like James won't be able to work on the hub adapter until mid next week and machining aluminum is currently the project bottleneck. So I did what what I had to: I signed up for Techshop. Time to learn how to run the Tormach CNC.
The doubling up of the hydraulic handbrake assembly for dual MCs should be straightforward.
- Made in the USA
- Design measurements available right on the product page http://www.wilwood.com/MasterCylinde...emno=260-15091
- Rebuild kit easily available
However, I'm surprised the part number is not stamped/printed anywhere on the unit. Given there are 5 ID sizes available, how would someone else know which rebuild kit to order? I might use a scribe and add that on.
As of today I'm allowed to use the CNC mill but taking another class on Wednesday to learn how to use the 4th axis attachment, which I won't be needing for this project. The machine the TechShops here use is the Tormach 1100, capable of making a whole lot of automotive stuffs. Anyways, aluminum plates in three thicknesses are in the mail, as are the new 5/16-24 thread helm joints.
I took apart the eBay handbrake assembly and started measuring and drawing things:
Here is a fun thought for y'all. This hydraulic rear handbrake project doubles as a failover device in case SBC should take a dump on me.
Really good for a first attempt, but needs revising. The holes didn't have the drill-through parameter enabled, the MC diamter is so precise (35mm) that it won't fit with the rubber protective boot (35.85mm).
Going to order a fancy endmill bit, design the second plate and attempt another round this week.
I slid mine back in the day - super easy to control.
(Well, easy to control right up until it went into limp mode and needed a tow home).
