Strange Gas Mileage From Recent Fill-Up - Really Odd
Old May 11, 2017 | 10:59 AM
babyboigsxr's Avatar
E55 AMG (SOLD), EvoSport CLK (SOLD), 2013 GsxR 750 (SOLD)
Arrow Strange Gas Mileage From Recent Fill-Up - Really Odd
I haven't had the chance to fully diagnose the issue "yet". But as I usually do when pumping gas, I fill it up to the top. I'm not the type to pump just a little bit here and there. Either all or nothing.
Allow me to preface with...
- Entire fuel system & gas tank has been replaced last year (the recall)
- I haven't floored it or driven crazy during this past fill-up
- I haven't left the car on or running
- I always reset the gauge after pumping gas
So... a few days ago, I was almost out of fuel. Probably a bad habit, but I usually pump gas when the light goes on. I filled it up all the way. I avoid "over-filling".
I get in the car, turn it on, and reset the gauge (miles driven from the last fill-up). It's typically between 315-355 miles on a full tank.
A couple days later, as I'm sitting at a red light. I glanced down at my gauges and noticed that I'm at half (which is fine). I drive a relatively good amount of miles day-to-day.
The only issue was... at half tank remaining... it showed only 69 miles driven!
That's when I wasn't sure what to think. I'm now at a 1/8th of fuel remaining and only 119 miles driven.
Kinda' odd. Has anyone experienced this?
Now I'm worried what the next fill-up will be like.
Old May 11, 2017 | 04:39 PM
Dublinoh's Avatar
E63 AMG 2007
Do you think the mileage recorded is correct? That is to say do you think you are getting much lower miles per gallon, or that the miles driven are not being accurately measured? Could be the gauge is not accurate?
Old May 11, 2017 | 07:22 PM
rapidoxidation's Avatar
2013 ML350 Bluetec
Not related to your question, but in my opinion it is a bad idea to run the tank less than 1/4 full. Why? Because the fuel pump is immersed in fuel to keep the pump cool. Running the tank empty deprives the pump of its cooling bath and results in an early demise of an otherwise long-lived system. And... How embarrassing would it be if you needed to quickly get out of town but your tank needed to be filled first because you were down to only a few gallons?
To your query: What Dublinoh said. Is your gauge (either fuel gauge or odometer) reading accurately or are you actually getting crappy mileage?
Old May 11, 2017 | 08:28 PM
CharlyE500's Avatar
E55 2006 / CLS55 / S450 / Jag XKR2011
My E55 never got 315-340 miles per tank.... normally about 250-270 miles. When I drove to San Jose and made 360 miles in one tank.
Old May 11, 2017 | 11:12 PM
2013 ML350 Bluetec
I may not be able to walk away from an E55 in the short run (but with 350 torques I'll not be too far behind), but it sure is nice to get nearly 800 miles out of a tank of diesel fuel if I want to...
Old May 12, 2017 | 03:20 PM
I want to safely say that the gauge is pretty accurate. I don't always get the best mileage on every fill-up. It's dependent upon my weekly driving. I mean... there are plenty of times when I get somewhere around 280-290 miles on a tank. Therefore, i think it's pretty accurate. All pieces and parts tied to the fuel system are relatively new.
I never knew that concept. Now that I know, I won't let it reach the "gas light" anymore. I appreciate the passing of your knowledge.
Regarding your last sentence... LoL. Unfortunately, it's happened a lot. Haha.
It should be. That's the first time I've ever seen my mileage that way. I just filled up my tank last night so we'll see how this week turns out.
When the car was stock, I usually filled up around the range of 315-330. After all my mods, I still get descent mileage. there were two rare instances when I actually reached 355 miles. Only cause I drove like a grandma the entire tank. I was curious to see the most miles I can pull off. LoL. Doesn't usually happen though.
Old May 12, 2017 | 03:53 PM
HeissRod's Avatar
'06 E55, '15 Jeep SRT8, '94 Mustang GT
Are you sure that the pump actually filled your tank? We had an issue a few weeks ago with a local station. My Jeep normally takes ~$60 max for a fill-up. I was halfway watching the fill-up and noticed that it had reached $75, then stopped directly at $80 showing that it had pumped around 30 gallons, but my tank only holds 25. Without going into a long story, which can be given later on request, we got a refund for the extra 5 gallons, then started to leave and found that my gas gauge was only halfway full. After more arguing, they bagged the pump and refunded us another 12 gallons of fuel, claiming it was a calibration issue.
I'd watch the rest of your tank for additional signs of a problem before diagnosing something that may not exist.
Old May 12, 2017 | 06:45 PM
oneslow55's Avatar
E55 amg
I get 13 mph I don't understand how many get high mph they must have feathers for feet
Old May 13, 2017 | 12:14 PM
SICAMG's Avatar
2005 e55 AMG
I can get 20 on the highway that's it.
Old May 15, 2017 | 01:04 AM
cetialpha5's Avatar
But did it show your mpg? Other possibility is that you left the car running or someone left the car running.
Old May 15, 2017 | 12:20 PM
hachiroku's Avatar
SPONSOR
2007 Mercedes E63 AMG
wow...the most I ever got was 320 miles 100% freeway driving. combined I usually pull 240-270 a tank. I usually fill up before empty though, but calculated mpg with 100% freeway driving was 20-21 mpg
maybe your sender unit is going out or dirty? my Audi A4 does the same if I don't always drive to empty and fully fill up often. usually it's because the sender unit is dirty.
if you do find out what is wrong please report back. good luck!
Old May 15, 2017 | 03:26 PM
Yuille36's Avatar
Veteran: Marine Corps
07 E63 AMG, 10 C63 AMG, 07 E63 Designo, 07 E350, 09 C300, 07 C230
The most that I was able to attain was 22 mpg in my E63, and that was all hwy miles on the PA turnpike.
Old May 15, 2017 | 07:10 PM
Strigoi's Avatar
2001 E320 Wagon, 2006 LBZ Silverado, 2007 E63 (sold), 2001 E55 (sold)
That's the best I've seen with mine as well over the last 7,000 miles.
Old May 15, 2017 | 07:41 PM
Dublinoh's Avatar
E63 AMG 2007
My last 300 mi highway trip mileage was 22.7, with a three gallon reserve that's 380+ miles. Also don't forget some of us have 21+ gallon tanks and some have 16+ tanks.
Old May 15, 2017 | 08:24 PM
Yuille36's Avatar
I know that I have the 21 gallon tanks, by the amount of money that I spend at the pump also it's not a good idea to ever let your car get extremely low on fuel, as there is sediment at the bottom of your tank, and that sediment could possibly get sucks up in your fuel pump, filter and lines.
Old May 15, 2017 | 10:12 PM
cetialpha5's Avatar
I think a key question is what was the mpg reading. That will tell you how many gallons it thinks was consumed to get to the 69 miles. If it's under 7, then everything is probably fine. Otherwise it's either a gas leak, bad pump, bad gas gauge etc.
Old May 16, 2017 | 10:27 PM
I never knew there were E55's with 16 gallon tanks. Always thought all the W211 E55's were the same for the most part. Interesting to know.
My mistake was I never bothered to look at what my MPG was. I was so caught up with the fact I only drove 69 miles to half a tank that I didn't bother to check the other readings.
