Help !!.... What is this sound ?
My 05 E55 (47K miles) has developed a Whirring sound on cold Startups'. This began happen after an oil change at the Stealership. The sound seems to quieten down after about a minute of running, but its still there.
I have since changed the Oil myself (Mobil 1 0w-40) swapping filters between Mann and Purepower metal filter. No change. The pulley's are all good.
I was told by a mechanic friend that this is due to the gears in the oil pump and that its common, but I'm not sure about his diagnosis. Sounds pretty bad to be a common occurrence.
Has anyone here heard this before or know what could cause this ?
that is absolutely the oil pump per your mechanic... remember there are iirc 6 metal gears in the oil pump....new and or different oil makes a difference....for instance.. when i use mobile 1 0 40.. it is the loudest....when i switched to bizol.. is was non existent.. i just switch back to the mobile 1 m formula 5 40 and its back louder again.... there are no issues that you have so rest easy...
ryanhere (05-25-2017)
Where did you obtain Bizol ? Can you please post the link ?
What spec oil did you use ?
Got it:
https://www.eeuroparts.com/Parts/869...rotect-B75511/
Got it:
Ok.. I put in Bizol 0-40 and like mentioned by fergsc32 , the sound magically went away.
so what gives? I always thought Mobil 1 0w-40 was the gold standard, but I think not after this experience.
Not a fan of M1 oil......last change was Royal Purple which seems ok but think I will try Amzoil or Liquid Moly next time around......
i allways had this same noise. On mobil 1 its loudest, now went with liquily moly leichtlauf 5w-40. its not as loud but def there. Can you take a video now with the bizoil? Cold start plz and after a while!
Sounds normal, a lot of cars do that at cold start. Nice cobra tank, have you felt any difference with it on?
Here is the sound post Bizol oil change. No whirring noise. The cobra tank really helps IAT Temps. With dual H/E I see Approx 8-10 f above ambient while cruising and a 30-35f temp jump at WOT
