AIT values and kompressor shut off
Old May 19, 2017 | 10:42 AM
Pieter Schepers's Avatar
E55 AMG Wagon
My E55 shuts down the super charger after one WOT pull. My first thought was to replace the pump but I decided to check things first. I hooked up the STAR and found the effective AIT value in volt. With a warm engine I was reading around 0.5V and after one pull it dropped to 0.22V.
According to this threat I should measure completely different values
https://mbworld.org/forums/w211-amg/...nge-specs.html
Am I missing something??
I also measured the resistants of the sensor and I was reading 1.2ohm (warm engine). The car gives me no fault codes.
Pieter
Old May 19, 2017 | 11:32 AM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
Your IC pump has gone bad
Old May 19, 2017 | 11:54 AM
FunkTron's Avatar
2006 CLS55
I would agree with Shardul.
Check your actual IAT before you go too deep into dissecting the voltages and such.
Old May 19, 2017 | 04:48 PM
MACEDON's Avatar
05 E55, 98 CLK320
How do you get this pump to run constantly btw? I wanna get my mechanic to do it when I bring it in to him
Old May 20, 2017 | 08:12 AM
E55 AMG Wagon
I will just change the pump and see if it solves my problem. They only cost 125€ so it's not the end of the world.
Do you need to rewire to have the pump constantly on or is it programmable?
Old May 22, 2017 | 04:31 AM
supreame's Avatar
W211 E55 AMG
I think mine is dead too . Ambient was ~16oc .
Old May 22, 2017 | 10:37 AM
BoostedAero's Avatar
2004 E55
What logging suite is this Supreame?
Old May 22, 2017 | 10:39 AM
FunkTron's Avatar
2006 CLS55
+1 I like it....but that is such a LONGGGGG period to view
Old May 22, 2017 | 11:08 AM
seanol's Avatar
2004 AMG E55
Looks like Torque logging exported to a .CSV file.
Old May 22, 2017 | 09:50 PM
supreame's Avatar
W211 E55 AMG
Yep that's what I used .
Old May 23, 2017 | 10:28 AM
FunkTron's Avatar
2006 CLS55
I've tried a couple times with torque but each time i go to export it gives me an error. I'll have to try a different device.
Old May 24, 2017 | 08:35 AM
2004 E55
I log with my android head unit and I always have to save the files to the microSD then pull it and look at the hard file on the PC :-/ The same thing happens when I use my ancient old Samsung Tablet
I guess with certain flavors of droid Torque struggles to export
