REAR DIFF
I guess it is possible and convenient to change ring gear ratios if/when you install an LSD, but gear ratios are completely unrelated to the LSD internals itself.
Let's make it clear for everybody going forward:
- LSD aftermarket (and factory options) consist of spider-gear replacing devices
- The input side of an LSD is a ring-gear mounting surface where the factory ratio ring-gear is mounted
- The output side of an LSD are two female spline drive cavities where factory axles slide into
- The device itself generally represents a conical shape tapering away from the ring gear
Ive been reading through old threads, people speculate that upping the ratio to 282/306 is counter productive in modified, higher hp m113ks. From what i understand changing ratios is considered the 'poor mans supercharger' and as such itll just introduce traction problems and i assune lower final drive for higher gears/speed? With 500 odd whp on dynojet would this be a recommended upgrade?
i think ill just ask the diff shop who im planning to install if they can easily/cheaply source the gear. If its a hassle ill just stick with stock.
this may sound like a stupid question, and I hope to know the answer, but would like to make really sure! I am new to the W211 platform, so please excuse if this has already been discussed.
Yes, I did search other threads!
How do I make sure whether my E55 has a HAG 215?
MY car is early 2004, still has 280 blower, was delivered in Dec 2013, but when I lie under the car and check the drive shafts, I cannot see any bolts. So as this is an early 2004 MY, it should have the old style bolted axle shafts, right? But I see no bolts. Is is safe to assume I have the HAG215 and new style splined axles?
Is there no difference to the diff housing / casting?
I ask this, because I already have a Wavetrac LSD and would like to understand what other parts I need for the installation of the LSD.
Is there a good reference thread about this somewhere?
Best regards,
Tadek
Best regards,
Tadek
Best regards,
Tadek
Best regards,
Tadek
Thanks!
Is there a good / preferred source for new bearings etc. as an alternative to Daimler / MB?
