Surge when coming to stop sometimes
Not yet but dropped 700 on new factory injectors and 45 on a new map sensor.. hoping those do it
2002 CLK 55 AMG cabriolet Eurocharged
I get a random miss but my setup is getting radical.
Did a sea foam and will report. Stock injectors are soon to be replaced with 550cc
Cheers
Have one O2 bung to fix
Cheers
05 E55, 98 CLK320
Which supporting mods do you need to do so you can upgrade the injectors? Any benefit in upgrading?
Currenly only have a 180mm crank pulley, wanna upgrade the injectors as preventative maintenance vs replacing them
I was told you need quite a bit to warrant bigger injectors. Pulley and tune don't require them.
Anything over a 168-172 (83 SCP) it would be a good idea to run larger injectors imho. More overhead for future needs
personally I would just replace all 8 with 550s even if I was stock and hadn't had injectors fail as prevent maint. you are talking a lot of work if the thing runs lean or hydrolocks and shells the motor.
