had glycol in transmission replaced radiator now replace torque converter
Old Jul 30, 2017 | 03:32 PM
benznewcomer's Avatar
porsche
*added video*-glycol in transmission replaced radiator now replace torque converter
since replacing the radiator the car has been running the last few months so im thinking the radiator isnt completely done??? if that is the case then am i ok with just replacing the torque converter? i am hearing this stupid droning sounds when accelerating at lower RPMs, it is like a buzzing/droning sound that comes and goes while accelerating and also experincing some jerkyness at lower rpms from time to time as well.
any thoughts would be appreciated, would this torque converter be ok for the E55???? any other parts i need to order to save my transmission?
DAACO MC18S http://www.rockauto.com/en/moreinfo....434366&jsn=455
thanks all i appreciate anyones help
Old Jul 30, 2017 | 04:48 PM
new55's Avatar
04 55
if your going to replace it i would put in a 2500-3000 rpm high stall converter -- no real down side that i can see -- do a search foe details
Old Jul 30, 2017 | 04:51 PM
porsche
the daaco is not that? the daaco is 210 dollars CAD so i am thinking the converter you speak of will be almost double the price isnt it?
Old Jul 30, 2017 | 04:54 PM
porsche
At ROCKAUTO they only have the Daaco the MC18S as a replacement part for the torque converter for the E55 so I am presuming that converter would be suffice? and its only 200 dollars CAD
Old Jul 30, 2017 | 05:08 PM
hayseed's Avatar
04 e55
may be fine
Old Jul 30, 2017 | 05:20 PM
porsche
anyone used the daaco before? it is listed on rockauto so i thought it would be ok
Old Jul 30, 2017 | 09:53 PM
SICAMG's Avatar
2005 e55 AMG
If you foot brake the engine does it make the noise? The only thing that will "drone" is the tcc in the converter. If you foot brake it and the noise "is" there, it can't be that. The tcc comes on in second gear"normally" so you will not hear any noise that can come from the tcc.
Just trying to narrow it down,
Old Jul 30, 2017 | 11:50 PM
porsche
i usually only hear the droning noise when lightly accelerating in low rpms, dont think ive ever heard the droning while braking, only when accelerating.
do you think next step is to replace torque converter? is the daaco a good one to replace it with?
Old Jul 30, 2017 | 11:59 PM
porsche
its like a droning/rumbling noise thats intermittent while im driving in a low rpm range, its more pronounced in highway driving, only when my foot is on the accelerator
Old Jul 31, 2017 | 04:58 AM
porsche
i was driving tonight and i took a video clip so you can get a better idea of the sounds i am hearing, along with the jerkyness for accelerating in the 1000-3000 rpm range i hear the noise as heard in the following video: note the noise comes in at 12 seconds/17 seconds/27 seconds into the video....it may be hard to hear it but with headphones in the computer i can hear it clearly: here is the link: https://uploadfiles.io/ckp9x
Old Jul 31, 2017 | 09:28 PM
porsche
At this point i am confused, spoke to transmission shop today and they say transmission has glycol and at this point to do transmission rebuild costing $6000. Mercedes Benz bulletin says if droning noise continues after a flush then to replace the torque converter....if i replace the torque converter it would be significant labor time so should i be doing the transmission rebuild while i am at it? I dont know what a transmission rebuild entails and what parts would i need to buy for them to do it besides the torque converter? new plates?
I have the new radiator i just installed few months ago that isnt leaking anymore (essen radiator i think its called) so i wouldnt need to replace that too right?
I am not sure should I just replace torque converter or do i do a new transmission rebuild? The droning noise has been going on for 6 months even after the radiator replacement and flushing so wouldnt the transmission be toast by now if the transmission was totally contaminated? would the cost difference between torque converter replacement and transmission rebuild be excessive? would I be able to source all the new parts online for a transmission rebuild or am i at the mercy of the mechanic???
thanks for any help
Old Jul 31, 2017 | 09:50 PM
SICAMG's Avatar
2005 e55 AMG
How could the trans have glycol when it was flush and new radiator installed.
Also I can not here the noise in vid.
Old Jul 31, 2017 | 11:43 PM
cnterline's Avatar
2003 SL55,2020 GTC ,2017 GTS sold ,2002 G500 Sold,2003 SL500 Sold,
You can get your trans rebuilt for less the half of that quote, imo ,if antifreeze was in your transmission it's just a matter of time, the antifreeze delaminates the clutch plates eventually I had this happen to me twice on two different cars over the years, again ,this was my experience , just an FYI ,
Old Aug 1, 2017 | 01:17 AM
porsche
if i go the transmission rebuild route what parts can i buy online to help with the pricing so that i can just pay the mechanic for labor? how much labor do you think is required? should i just drive the vehicle until the transmission totally fails? it still drives fine for the last 6 months outside of the low rpm jerkyness and droning
Old Aug 1, 2017 | 01:44 AM
porsche
sic the mechanic said they cant get all the glycol out in just 1 or 2 flushes and it needs multiple flushes so there still maybe small trace of glycol
Old Aug 13, 2017 | 09:16 PM
Khalid sidi's Avatar
E55 AMG
If there are no symptoms of the trans failure of an 03 e55, then only the radiator should be replaced along with a trans oil change?
What radiator should be bought, ?
Thanks,
Old May 14, 2019 | 07:47 PM
dblock110's Avatar
C32 AMG
what did you end up doing? i have the same thing. replaced radiator with nissen but still have the slight drone on light accelertion.
an mb tech said it sounds/feels like a torque converter
i am also debating if i should just do TC and Trans at the same time, or to just do the torque converter first.
Old May 14, 2019 | 07:54 PM
E55amg0220's Avatar
Veteran: Air Force
2003 Mercedes E55 AMG
The coolant did damage .... how much who knows may last years may last weeks, but why pay for the labor twice. The trans has to come out to replace the TC id take care of the trans while its out, work smarter not harder.
Old May 15, 2019 | 12:33 AM
dblock110's Avatar
C32 AMG
any idea on costs of all this? i see used trans for 1k and new torque converters for $200. how much is labor / how many hours haha
how much is a trans rebuild if a used one is 1k. and i dont need reliable transportion really so my plan was to drive it as long as possible.
if i ONLY got the converter first, could the infected trans infect the new torque converter?
Old May 15, 2019 | 01:11 AM
E55amg0220's Avatar
Veteran: Air Force
Its a relatively easy trans to work on and remove an while in there replace the rear main seal it costs 20.bucks an is good peventative maintance.
I dont know how good the used trans are never know what ur going to get these transmissions are not that hard to rebuild if u take your time. The rebuild kits can be had for 200 to 600 bucks for good high quality parts. There are tutorials on here and the net that show step by step how to do it. Most shops round my parts charge 250 to R&I a trans. Id call round an see who offers what for how much and make sure their good at what they do.
Old May 15, 2019 | 07:53 AM
dblock110's Avatar
C32 AMG
ok thanks. at first glance it seems like when the time comes i should buy a new torque converter, get the rear main seal replaced, and rebuild the trans for the cheapest option. ?
