What's this noise?
Old Sep 29, 2017 | 03:04 PM
Dan0's Avatar
Non yet :(
What's this noise?
Thanks guys.
Old Sep 29, 2017 | 05:29 PM
FunkTron's Avatar
2006 CLS55
sounds like a shot bearing......
does it go away after warming up?
Old Sep 29, 2017 | 06:41 PM
E55amg0220's Avatar
Veteran: Air Force
2003 Mercedes E55 AMG
could be a couple of things .....what comes to mind for me is
failing intercooler pump
bad dual idler pulley mine made a similar sound cause it was missing some of its plastic backing
or alt starting to go bad
Old Sep 29, 2017 | 10:31 PM
Dan0's Avatar
Non yet :(
Thanks for the ideas guys, I'll take a closer look at those things tomorrow.
Old Sep 30, 2017 | 10:55 AM
layzie12g's Avatar
2008 Mercedes Benz E63
My car makes the same noise. I took off the undertrays and ran it. Its the oil pump.
Old Sep 30, 2017 | 03:24 PM
E55amg0220's Avatar
Veteran: Air Force
Wow thats a noisey oil pump if thats true wouldnt run the car again til fixed if ur sure
Old Sep 30, 2017 | 04:08 PM
C32owner's Avatar
2018 E63s AMG (Current) 2011 CL63 AMG (Sold) 2005 CLS55 AMG (Sold) 2004 C32 AMG (Sold)
I would agree to the intercooler pump first. I just changed out the bearings on the belt wrap kit and pulley set. They didn't last long at all if you have those installed.
Old Oct 3, 2017 | 12:52 PM
211.070's Avatar
2005- E55, 2007 GL450, 94 B3000
This is the closest answer. Usually the oil pump chain tensioner gets weak, and allows the chain to make contact with the front cover. If someone wants this noise repaired you might as well replace the oil pump if you are that far in to the repair.
