Just purchased 2nd e55 to put on a diet.
Old Oct 13, 2017 | 12:52 PM
MACEDON's Avatar
05 E55, 98 CLK320
Lose body weight. I'm 280lbs, I should be around 240 lol
Old Oct 13, 2017 | 01:16 PM
JoeJErnst's Avatar
2019 Jeep Trackhawk, 2002 CLK55, 2014 911 Carrera
Originally Posted by drothgeb
My drag wheels (CLK 16s with Hoosier 255/50/16s) is probably 50 lbs lighter each haha. I haven't actually weighed the difference but I would bet at least 50 each. The CLK rim is 14 lbs, I bought mine for best offer $90 each from here but I don't see any that cheap any more at the moment: http://www.ebay.com/itm/391871157217?rmvSB=true
Other style CLK rims and most other 16" rims will not fit, has to be the style you see in the link above.
You might be able to call the shop in the ebay link above and see if they can still sell them.
I think you're being a little overly optimistic. My stock rears weighed 53 lb each according to my bathroom scale. The CLK rims are 14 lb, the Hoosiers are 22 lb (according to Tire Rack), plus you'll add another 2 lb or so for the spacers and longer bolts, bringing the total weight of each CLK setup to about 38 lb. That's about a 15 lb savings per side. Of course it's saving rotating mass, so there's a multiplier effect, but I don't know how to calculate that.
Old Oct 13, 2017 | 01:43 PM
drothgeb's Avatar
Veteran: Navy
2005 E55
I may be over estimating a bit, but sorry I forgot I got my car with different wheels not AMG. They are lorinser 19" or something like that, and the heaviest wheel/tire combo I have ever picked up.
Old Oct 13, 2017 | 07:17 PM
dirtbagit's Avatar
2066 e55
lol need to drive it via a remote!
Old Oct 17, 2017 | 11:51 AM
Alex L's Avatar
CLK56TT (WIP), S65, RR 5.0 S/C
Originally Posted by dirtbagit
so the question is what else can I pull following my simple rules.
Glass -> polycarb.
Old Oct 19, 2017 | 10:58 PM
dirtbagit's Avatar
2066 e55
Overall you really need to go hardcore to get anywhere on these things, I've done the real simple stuff batteries, seats and have saved 130ish lbs, will pin the hoods soon that can save between 20 to 30 lbs depending on what I want to do with the latching mechs. I see maybe 150lbs without going nuts. To get to 200+lbs I'll need to go with polycarb, which I'd like to do but I don't really have the skills for that so I need to find somebody to do it. Wheels are the next big win, then two piece rotors, so I'd be at roughly 300lbs at that point. That would be about 60ish hp net equivalent, not really exciting but is healthier for the car.
hmm still a work in progress.
Old Oct 20, 2017 | 02:43 AM
  #32
Alex L's Avatar
I agree. I’d be tempted to chuck all the interior and go bare shell but then why do it to the four door saloon when a CLK or a C class coupe can do it even better.
Old Oct 20, 2017 | 09:28 PM
  #33
dirtbagit's Avatar
2066 e55
thanks, Yes no doubt a 2 door would be a better start, just don't like the looks of the clk. Now a c class is not a bad idea but like I said paid next to nothing for the e55.
Old Oct 20, 2017 | 09:45 PM
  #34
drothgeb's Avatar
Veteran: Navy
2005 E55
I know you said you don't want to pull out the sound dampening matting, but you should pull up the floor and see how thick that **** is.
Next you can start looking at removing unnecessary equipment. I'm sure there is more depending on what you are willing to sacrifice but off the top of my head:
  • Sunroof: Even if you leave the sunroof in place, you could potentially remove the motor and maybe some more hardware associated with it? Just leaving it closed and disabled.
  • EGR Valves(If you're cool w check engine light): I read in a post some where that they pulled the EGR valves and then tapped/threaded the holes to plug them. In this thread some one talks about removing EGR and then disassembling the dash, covering the check engine light with electrical tape so it doesn't show haha. https://mbworld.org/forums/w211-amg/...gr-valves.html
  • SAI: (If you're cool with check engine light): Can remove SAI pump and hardware
I don't know anything about the EGR and SAI, Just crap I've read about here and there so I can't give any insight on them, just something that may be unnecessary and removable.
Old Oct 22, 2017 | 08:48 PM
  #35
kustom2k1's Avatar
03SL55
Take a jigsaw and a drill, cut and drill holes everyfknwhere!
Old Oct 27, 2017 | 12:17 AM
  #36
dirtbagit's Avatar
2066 e55
Ok my garage is not heated so I'm not going to do much on it for a while, but I'm going to gut the sound proofing for sure and also gutting the rear doors and fixing windows in place and hoping to replace glass with polycarb some day.
Seems to me that the headers on back on these things are heavy, is there anything that can be one in that area?
Old Oct 27, 2017 | 01:21 PM
  #37
drothgeb's Avatar
Veteran: Navy
2005 E55
Well, regardless of the weight difference you'd probably want to go with a header set up. The factory manifold is garbage. People talk about gaining 40hp on here pretty frequently just from the switch to headers. There is also two sets of cats, a set of resonators, and a set of mufflers you could pull off and dump tube or straight pipe if you wanted to cut a bunch of weight.
I believe a set of long tube headers already removes the main cats and resonators. Mid length install will leave the resonators but still remove the main cats, and shorties will leave everything and just remove the factory manifold.
Or if you wanted to save save the muffler/exhaust tip look you can gut the mufflers. There is a thread on here about it. It seems most people believe the change in sound is minimal but those suckers are packed full of ****.
Old Oct 27, 2017 | 02:15 PM
  #38
JoeJErnst's Avatar
The factory mid-section is pretty dang heavy, and I assume the resonator and mufflers are too. Go old-school and install a pair of header mufflers with turn-downs. Remove the rest of the exhaust and put on an E500 rear bumper for good measure. ;-)
Old Oct 29, 2017 | 12:38 PM
  #39
germangearhead's Avatar
2004 E55 AMG
it has a rebuilt title so it was very cheap has some miles don't really care what happens in the end.
Putting second e55 on a diet, only rules are that it looks normal from the outside and maintains safety equipment.
starting with seats, will use jegs if they will fit, just 2 up front rears gone. Removing all the hood and trunk lift gear will pin if I can, shelling out the rear doors window will be in up position also might seal the rear doors and remove hinge equipment, don't have a plan for this part yet. Doing lighter battery and wheels, Think the sound system in this thing is heavy probably will remove that too. Don't think I'll pull the sound absorbing material.
Might switch to coilovers, pulling the air compressors too.
if I could save 500lbs that would be awesome, might need to stay away from the beer for awhile.
Not to concerned if I don't get there just messing around.
I am working on making some carbon fiber fenders to start maybe do a hood as well. But that could definitely save some weight.
Old Oct 31, 2017 | 08:34 PM
  #40
BC928's Avatar
2006 E55, Various other German and ‘Murican
The front of the e55 has been lightened to offset the sc.
Fenders and hood are aluminum.
Before you figure CF I would determine the heaviest pieces. Hood still seems heavy.
Old Nov 1, 2017 | 12:19 AM
  #41
2004 E55 AMG
hood, trunk, bumpers, side skirt would be the first ones on the list
