Any codes after removing EGR Valves?
Old Mar 12, 2012 | 08:08 PM
claywillard's Avatar
2005 E55 AMG
Has anyone that have removed the EGR Valves received a CEL and / or any alarm codes?
Old Mar 12, 2012 | 08:42 PM
blackbenzz's Avatar
haters crazy
You will get CEL for EGR malfunction
Old Mar 12, 2012 | 08:56 PM
GT-ER's Avatar
2005 E55 AMG
Yep, you'll get a CEL. What did you use to block off the valves?
Old Mar 12, 2012 | 10:43 PM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
Sneakneon fabbed up some block off plates.
Old Mar 12, 2012 | 11:09 PM
GT-ER's Avatar
2005 E55 AMG
I want to remove the two valves next to the supercharger. They are there for decoration right now.
Old Mar 13, 2012 | 03:03 PM
2005 E55 AMG
I read in another post of running a 3/8" NPT tap into the exhaust hole/port and plugged it with a steel pipe plug (used hi temp silicone to ensure seal and as thread lock). Not sure exactly where the port comes from so I carefully pushed kleenex into the hole to catch filings. By pre-lubing the tap, any filings stayed attached to the tap anyways. Sucked kleenex out with shop vac. I capped the supercharger ports with OEM caps (there is a factory port cap on the unused port on the passenger side of supercharger below the supercharger's EGR port). Caps were $6.75 ea thru the dealer.
Old Mar 13, 2012 | 03:07 PM
GT-ER's Avatar
2005 E55 AMG
Nice, I'm going to do this.
Old Mar 13, 2012 | 03:11 PM
xpl0sive's Avatar
CLS55 AMG
is there a way to code out the EGR same way as there is a way to code out the secondary O2 sensors?
Old Mar 13, 2012 | 04:07 PM
2005 E55 AMG
I emailed Jerry at EC and he informed me that he cannot.
I would also like to remove Secondary Air Injection. Looks easy to do, but this would probably be even worse than a CEL. Haven't searched yet, but I imagine someone tried it.
Old Mar 13, 2012 | 04:31 PM
GT-ER's Avatar
2005 E55 AMG
I removed my secondary air injection. I have a few codes but I blocked my CEL in the cluster so it doesn't bother me.
Old Mar 13, 2012 | 07:27 PM
2005 E55 AMG
How did you block?
Old Mar 13, 2012 | 08:15 PM
xpl0sive's Avatar
CLS55 AMG
with black electrical tape im guessing? lol there's actually a way to turn off the check engine light in STAR, the only problem is, it will be always off, so if there are any problems you wont know about them
Old Mar 13, 2012 | 10:36 PM
GT-ER's Avatar
2005 E55 AMG
How did you block?
I covered the bulb with tape and assembled the cluster together again. Looks flawless.
