can you trickle charge the aux battery?
can you trickle charge the AUX battery? they're not AGS so just checking...
If I'm not mistaken, the small battery is solely for emergency power for the brake hydraulic pump.
Maybe someone who knows better than I will chime in.
Additionally, if the BCM determines the load capacity of the main battery is low, it will connect the auxiliary battery to the main system while simultaneously disabling convenience features in two stages depending upon voltage.
https://dyw03owr7vs3n.cloudfront.net...8a.?1544113524
I'm all for saving a few bucks when it makes sense, but ignoring warnings about the battery technology specified for my car is not such a case in my opinion.
Also, the aux battery only charges when the engine is running. A Battery Tender connected to the main battery will have no effect on the aux battery as it is isolated from the main buss.
In fact one of the most common failure modes appears to be the water evaporates and the capacity diminishes. It is very possible to restore function by adding water and I guess it can take a few months for the chemistry to catch up with the mats. I am currently performing this experiment on my 11 year old aux battery on my S550 (it's a group 49 so quite large like the W211 main battery).
