Fuel Filter/ Paper Insert
Old Oct 7, 2017 | 04:41 PM
Pmarino's Avatar
04 E55 AMG BLK/BLK(MyDD), 06 CLK 500 (wife's) 07 ML500, 2012 C300(son's)
https://mbworld.org/forums/w211-amg/...p-replace.html
It is possible to replace the paper filter without completely removing the sending unit. A bit of PITA but worth the cost savings of a whole new sender. Disclaimer: This was preformed on the A 211 470 6494 sender that is paired with the A 211 470 00 00 pumps. YMMV
I could not wait for the overseas filter. I took the filter out of this sender (Fuel Pump Assy 2114704094 )( http://www.ebay.com/itm/Brand-New-Me...53.m2749.l2649
https://www.amazon.co.uk/gp/product/B00FZGP17G/ref=ox_sc_act_title_1?smid=A1F8YGP86NG3IP&psc=1
https://www.ebay.com/p/Febi-Bilstein-Car-Fuel-Filter-Genuine-OE-Quality-Service-Part-No-39831/1837686703?iid=192282650814&_trkparms=aid%3D222007 %26algo%3DSIM.MBE%26ao%3D2%26asc%3D41376%26meid%3D f3dab5b4eccf436fbe86958f2897a207%26pid%3D100005%26 rk%3D2%26rkt%3D3%26sd%3D192223060128&_trksid=p2047 675.c100005.m1851
http://www.febi.com/uploads/media/fe...Ansicht_13.pdf
Remove the wire connector
Rotate the top 1/4 turn counter clockwise and pry up top. Remove the paper filter
Drill out new filter element and replace.
Old Oct 9, 2017 | 05:05 PM
FunkTron's Avatar
2006 CLS55
great work.
I remember my old VW GTI had an inline fuel filter that was a "non-servicable" item. My mechanic friend said "we definitely want to change that out".
When we did, it looked like mud coming out of it.
For informational purposes.....is there 1 or 2 of these in the tank? I'm yet to dig into that region of the car.
Old Oct 9, 2017 | 08:21 PM
Pmarino's Avatar
There is only one fuel filter in the sending unit. It’s located in the drivers saddle tank under the rear seat. There are 2 fuel pumps located in the passenger (right) side. They have a “sock” filter on each pump. The sock filter would require some jury rigging to replace.
Originally Posted by FunkTron
great work.
Here are some pressure readings
https://mbworld.org/forums/w211-amg/...-pump-r-r.html
