trunk will not auto open or close/lock
Old Nov 1, 2017 | 09:39 PM
MikeE63's Avatar
2008 E63
so this is weird. my trunk out of no where will not open all the way automatically or close and lock. it pop with the remote and the button on the drivers door. but it will not fully open. the little red buttons in the trunk lid are no longer lit up either. I checked both fuse boxes but couldn't find anything. has this happened to anyone else?
Old Nov 1, 2017 | 10:50 PM
Strigoi's Avatar
2001 E320 Wagon, 2006 LBZ Silverado, 2007 E63 (sold), 2001 E55 (sold)
Wires probably broke. Do a search on here, it's a common issue.
Old Nov 2, 2017 | 11:40 AM
Dublinoh's Avatar
E63 AMG 2007
This happened to me, wires brake right where they exit the hinge. Sort of time consuming to remove stuff to get to it but an easy fix. Check them all, you’ll find cracked insulation on the ones not broken. Patch in the wires, adjust so the wires don’t bend at the same spot with opening and closing and you should be good. Search is your friend here for DIY and pics.
Old Nov 2, 2017 | 11:27 PM
MikeE63's Avatar
2008 E63
thanks for the information. I have yet to find a forum with a good search tool. I tend to find that forum members are very helpful. I'll start taking it apart this weekend.
Old Nov 3, 2017 | 12:00 AM
Strigoi's Avatar
https://mbworld.org/forums/e-class-w...ate-lamps.html
Pic of broken wires: https://mbworld.org/forums/e-class-w...ml#post4047470
Old Nov 3, 2017 | 09:02 AM
Dublinoh's Avatar
E63 AMG 2007
Search is good if you go into “advanced search” and search by thread, give it a try. There was enough slack to allow simply strip/twist/solder/insulate solution.
Old Nov 3, 2017 | 01:52 PM
MikeE63's Avatar
2008 E63
Thank you for the help
