VRP superflo Intercooler pump results
Although I guess it helps to be in the most lenient state in the country when it comes to speeding.
In some parts of Virginia, they'll literally throw you in jail and/or tow your car on the spot if you go over 80 mph absolute or 20 mph over the posted. It's an incredible scam by the local jurisdictions and defense attorneys. Class 1 misdemeanor, too, which means it goes on your criminal record (although the good news is that most employers are sane and won't hold it against you).
In some parts of Virginia, they'll literally throw you in jail and/or tow your car on the spot if you go over 80 mph absolute or 20 mph over the posted. It's an incredible scam by the local jurisdictions and defense attorneys. Class 1 misdemeanor, too, which means it goes on your criminal record (although the good news is that most employers are sane and won't hold it against you).Utah is pretty cool but they arent exactly happy bout speeders either. Haha
Went out and bought torque pro cause i heard its a bit better than dash command. It also reads in F not C so that helps i didnt have to do any conversions.
Went out its a balmy 49 to 50 degrees today in good ole Utah and cruising i was hitting a high of 62.7 degrees an low of 57.6 degrees F thats less than 10 degrees above ambient in the low an just over on the high .... not bad.
Found a small stretch of onramp that allowed a full WOT too just shy of top of 3rd an over 135mph!! By the time i shutdown my high IAT was just over 87 degrees i pulled off next exit which was just a 1/4 mile away an temps were already 69. Got right back on an hit 130 MPH going up the on ramp an my IAT was 89.3 F ..... id say thats pretty dam good for just a superflo, VRP heat exchanger, an 76mm pulley no split cooling, no meth, no trunk or underhood tank. But both underhood tank and meth are coming as well as MBH headers an mid pipe.
Also waiting for my updated tune from tony as im still pretty rich.
Your system is dialed in nicely now. I don't even think I would bother with a w/m kit for yourself to be honest. Just get a retune with leaner afr's and you are good to go mate. Your intake Temps for top of 3rd gear pull is unheard of with your setup. Bloody awesome results.
I honestly cant explain it but i did do a data log with torque pro so i have that as well .... as soon i figure out how to post that or get turn into graphs i will post that too.
I still think an underhood tank is a must and like i said ill see where i am after that as well. Plus with the headers an such that should get me real close to where im wanting my car power wise.
Africa huh ..... one of the very few places i have yet to visit .... but i plan too. Been all over the world being ex military an did enjoy all the traveling ..... last 4 big ones i want to go too is africa, australia, eqypt, and brazil. If i can do anything else to help anyone make an informed decision just ask
The headers will definitely help you gain more power.
Shot for your testing of this pump, I know for sure when mine takes a crapper I will be replacing it with the VRP superflow for sure
Africa will always be here bud lol.. If you swing by this way, give us a shout.
Here is NZ our temps can range from about 0-35C over the year. I love dry winter conditions car feels so much more responsive and powerful and angry.
I would like to see your logs in the summer time, E55amg0220 so that we can confirm the appealing recovery, peak and cruising temperatures. I'm not disputing your findings, but when I was researching cooling before doing my upgrades there were plenty of claims that high flow pumps made no difference or in some cases people were claiming it made things worse.
See these threads, the thought seems to be unless you have added restriction to the system (multiple HE's, engine-bay or trunk tanks) that high flow is bad.
https://mbworld.org/forums/w211-amg/...n-cm-90-a.html
https://mbworld.org/forums/w211-amg/...-vs-wp136.html
- P Rat
- P Rat
- P Rat
(Car had split cooling and these various combinations only. lower HE was the V3 (single pass))
As Flow increases, starting temps and recovery improve. as you increase capacity and cooling area the peak temperatures drop.
- P Rat
The only thing you need to worry about is frothing coolant with too fast of a pump, that is where the force of the impeller literally rips dissolved gasses out of the fluid. In which case your flow rate will tank because of the compressible gasses. I have read some people claiming to see this with the CWA100 but most people seem to love it so I doubt it occurs.
