E55 made 540whp 663wtq on 91 pump gas with bolt ons
E55 made 540whp 663wtq on 91 pump gas with bolt ons in Las Vegas
Special thanks to Anthony Lawshee over at Race IQ for getting my car dialed in at the dyno day in Las Vegas, NV this past Friday. I was expecting close to 530whp but he was able to surpass that and I’m very happy with the results.
Even at my elevation of 2200ft aboben sea level on 12psi of boost, long tubes, 82mm Tb, 2 heat exchanger exchangers with 10 gallon trunk tank and water injection.
Video of the pull on the dyno:
https://www.youtube.com/watch?v=wDlE...ature=youtu.be
Anthony Lawshee (11-10-2017)
Anybody else played with an E55 on the dyno and found you can manipulate the torque readings by how you apply the throttle? It's really weird how that works.
Lmao..Maybe a on pos mustang or d.d..
Dyno jet is interia setup and can't be played with!
This dudes car is a power house and nice tune and setup...
Das_it16 (08-14-2018)
Das_it16 (11-06-2017)
thanks man. 90% water 10% meth. This mixture doesn’t change my afrs and I’m only using the water injection for cooling. I’m too scared to tune for it since I just popped my last motor in July :/
GM_Lover (11-05-2017)
Also saw in your sig that you're running the UPD intake box spacers. How do you like them?
Can Anthony chime in here and explain what his new cams do for this kind of torque curve?
Meaning take this exact car and add cams.
I got my fuel pumps directly from Walboro's website: http://walbrofuelpumps.com/walbro-f9...-fuel-pump-e85
