E55 IAT
Just so you know, killer chiller is supplemental to the heat exchanger, not a replacement. If you mean what you said, which is that you took off and did not replace the heat exchanger, that's why. You have to put it back on haha.
Killer chiller uses the factory ac to do some pre-cooling. It doesn't have any where near the required cooling capacity to be your sole cooling component.
Yeah man, you have to get that heat exchanger back in. Once you pull the KC out, and get the heat exchanger back in, here is some ones blog that should help getting the KC in correctly.
https://tinyurl.com/y99alaue
EDIT: I'm wrong, some people are removing heat exchangers, I don't image this would work without a huge trunk tank though. Do you have a massive reservoir in your trunk?
If you are still using the OEM tank cross connected with engine coolant that is your problem. You need a large reservoir that is not just a surge tank but plumed in series with your IC and pump. Basically what the guys are doing that are running this way are just pre-cooling the intercooler coolant and having a large enough water capacity that a pull doesn't deplete the cold water stored in the tank. This is only good for short pulls, basically drag racing. After each run you will need to let IC coolant circulate long enough through the KC system to fully cool all of the coolant in the system again. The KC still doesn't have the capacity to remove the SC heat, its just the large capacity of pre-cooled water that is doing the cooling.
This is a false statement. I have a KC installed with the factory HE blocked off an I can isolate the cabin evaporator if AC isn't needed. I have a temp probe in the top of my tank. The KC keeps my tank water 25-30 deg F colder than ambient during cruise. The theoretical coldest a HE will get the tank water is ambient so a HE will heat that water and work against the KC. I have had to put a bit of glycol anti freeze into the water as I have often seen the KC water below freezing on cooler days. A hard pull from say 60-100mph will raise the tank water by 10 deg F but then it gets rapidly cooled again. I am having issues with 'hunting' which is the KC supplied TX valve not happy. I see the water cooling in the tank but then sometimes stopping and rising under steady cruise before dropping again. I have an externally adjustable TX valve ordered which should allow adjustment to stop the hunting. Despite this the tank water is always less than ambient. The KC is a great investment if installed correctly and you can monitor the water temp.
Something wrong with the installation.
He didn't specify but I believe his problem is that he removed the heat exchanger, installed KC on an other wise factory cooling system with no trunk tank, just the factory cross connected coolant reservoir.
Edited my first post to minimize the number of people posting about that, that didn't read the rest of the thread
I want to attach an image of my tank but there is no "manage attachments" option at the bottom like there always used to be. Help?
