211 E63/E55 o.e. p30 limited slip
Purchased this unit from a local salvage yard, for the ring and pinion.Had already purchased a Quaife for my car and wanted to advance my gearing a little. Later discovered it was a p30 car. Vin verified by my local dlr. Anyway its mint with about 70k on it. Will fit e55 / e63 / cls 55,63 as well. I'm asking $500 for it. Thanks for looking.
I'm located in NYC, my install cost me just under $600. It wasn't too difficult, but the diff has to be removed from the car b4 the lsd can be installed.My car as well as a few others I've driven feel much more stable and acceleration is definitely improved with lsd.
Sorry for the rookie question but rear ends are not my forte (hold the jokes). How does this unit you're selling differ from, say, the Quaife or Wavetrack?
It's basically the same as the other units you mentioned except it has a slightly less aggressively lock up function. That translates to its a little more subtle. Mercedes/Amg designed it to improve acceleration and handling on the street. I wouldn't be selling it, but I bought it for the 63 gearing and found out it was a p30 lsd after I already purchased an aftermarket unit
I'm not sure if it can fit a c63 but I'm attaching the vin so u can try to cross reference. I do think there's a good chance it will fit in your diff housing. Just not sure about the axles WDBUF77X87B171393. Thanks for the interest.
