Crank pin kit
The ASP one is using the existing key way as holding all the force with two other pins added. But still it seems the load is on the factory key way. Not sure if that's the way to go but Shardul offers them for $80.00. Any tips from the big crank pulley guys out there?
Happy New Years Everyone 🤘🏻
This was right before I tapped the pins into place
Also how did you hold the crank ? With the flex plate tool or crank pulley tool?
you get the point
Sharp bits give precision while drilling. I do not think you will have an issue at all.
I used a new OEM bolt and borrowed an OEM crank holding tool. Set oven to 200* crank pulley into oven 20 mins, lube snout up. Put on some welding leather gloves and let thermodynamics do their job and the crank pulley will just slide on once the key is lined up. I used a little thread locker and over torqued bolt to +120 degrees. She has been solid for 10k miles now and doing good (knocks on wood)
Getting the bolt locked down was the hardest part.
