Was 2009 E63 AMG more reliable?
I sold my E55 about 6 months ago and am looking to get into another AMG. I was primarily looking for an E55 but came across an E63. 2009 model year and the seller says that it doesn't suffer the same problems as the previous E63 regarding head bolts and cams. Is this true? Also, how is the 7 speed tranny for reliability?
Thanks!
Thanks!
So, I barley drove the car 10 miles home before I started taking her apart only to find the Intake Manifold wet with an oily goo and the Intake runners totally carboned up. In addition there was a distinct pull to the right so I ended up rebuilding the front end, had the IM rebuilt by Rebuild Master Tech in Pompano Beach, Fl. who did an exellent job and showed me how ridddled with rusty holes my Throttle Plate was which they replaced with their extra beefy plate they sell on eBay. I had also busted off a fitting attaching the Breather hose and those little posts which have o-ring fasteners on them to hold down that Breather hose were all disintegrated, so they managed to find a replacement top half!!!! I was so pleased that during the time that they were repairing this, I was taking apart the front Suspension and ended up replacing both front air Struts with their refurbished ones when I brought my used ones in to exchange for theirs when I picked up the Newly refurbish IM. Both their work on the IM which was fabulous and Newly repainted to boot and their front Struts have worked and operated flawlessly since I have installed them.
I also was aware of the Headbolts issue and toyed with the notion of walnut blasting the Intake runners to clean up the carbon, but in the end I decided to bust the move and do it right by removing both Heads and having them rebuilt by Xtreme Heads in Palm City, Fl who were top notch and had more than sufficient high end equipment to not only do the head rebuild, but they could actually create an entire new head from scratch if absolutely need be, for big dollar I might add as it was explained to me that since they don't own the CaD software for my Heads, the only way they could do it would require 100s of hours of photographing CAD images into their computer of every nook and cranny of the Head. Turns out their specialty are Porsche Heads, and the admitted it was their first time working on an E63 Head, but after fully being briefed as the equipment they would use to measure valve tolerances, double check Spring weights etc., I had no apprehensions whatsoever. When they determined that 8 of 16 Intake Valves were bent, they called me and I confirmed to them that I would order the OEM Valves as compared to using their supplier, I was impressed to say the least. I might also add that it was only after seeking out 3 other "Head" shops and seeing just how unorganized some choose operate that I was thoroughly impressed with these guys just upon walking through their door. No showroom needed, just a hardcore very organized clean shop with top of the line equipment and I was sold.
I've since the rebuild put around 8000 miles on the car and have to smile every time I'm on the road effortlessly overtaking on demand not even coming close to redline! The Struts absorb even the most obtrusive pot holes at speed and the instant self leveling in aggressive and, if the situation demands, "twitch" steering combined with that extra beefy swaybar up front make for incredible handling considering the beasts weight of 5k lbs!!
Next up is to upgrade the sound system with an Audisson Bit Nove and some Amps and then there is the rear Subframe Bushings as well as the rubber driveshaft ends, a Rear Main Leak, rear shocks and Air Springs and while I'm at it replace the rear wheel hubs!!!
Thanks!
The E63 is a good platform, and their issues can be resolved. My 07 E63, has never had cooling problems that the E55 suffers from.I have owned (2) E63's and (1) C63 and neither of these cars, gave me any issues. Compared to the issues that some E55 have faced. Their are far more complaints from E55 owners, then there are E63 owners on this forum.
But E55 owners will always talk, I rather listen to someone that has owned both platforms, then to someone that never has.
I've personally seen three 63 engines apart in my local dealer because of the head/cam issues, and I've had long discussions about the 7-speed transmissions and the multitude of issues they have on a regular basis as well. It is anything but a reliable platform. I deliberately didn't buy an SLS when I semi-retired my CLS55 because of the continuous issues of both the 63 engine, and Mercedes' use of that Getrag transaxle which is also as hideously unreliable as the regular 7-speed that comes in the E63.
I've only owned the CLS55, and not an E. I don't really consider an E a decent car. I just chose the CLS55 over the S65/SL65 at the time I was looking to replace my BMW. I've driven about 8-10 E63s, and wasn't impressed with the engine either. It never was a sufficient replacement for the 55.
Personally, I think maintenance issues are minor compared to serious, systemic design defects and flaws that resulted in a number of lawsuits against Mercedes from pissed off customers. If people properly maintain their cars, the 55 is relatively bulletproof when compared to the 63. You can spout whatever nonsense you want, but there was nothing well designed about the 63 drivetrain and anyone with sense would stay far away from it.
I haven't had hardly any issues with my CLS55. Aside from the usual Mercedes gremlins which you'll find in any of their cars. Not sure where you're deriving that from.
You are (you're) only doing them a disservice by pretending they don't exist.
I could give you a list of 20 reasons why to not buy a Mercedes at all.
