E55 Mysterious battery drain HELP
I have done the seat thing on the CLK but you would have to research the correct plugs to pull on the E-class or find the fuses they use. On the CLK there is a row of plugs under the front of both seats. I presume the E is the same but I haven't needed to look thankfully.
Must be running all the time and not syncing off as it turns off with the ecu to sleep..
If you changed the volt reg,battery,alt,and aux ,this is the gremlin..
yeah man could be, but I know people complained about it in regards to it sitting for a weak, this drain was really aggressive but I totally agree with you. I'm thinking about getting a trickle charger and calling it a day. i also read that the 2004's have the bcm module issue I doubt the previous owner changed it, haven't heard from you in ages, hope all is well! I fixed that mischievous hiccup too lol it was really bad man, tony sent me another file smh all those headaches and all I took was one file haha
