How much is my car worth
#155
'99 and '05 E55 AMG
FWIW, I just pulled a D service at 140,000 miles and here is the data from the SBC unit:
Bremsenzaehler - 301,454 (for reference, this count was 235,986 at 100,000 miles)
Pump cycles - 11,224,600
DJ_GetPmpLD (Estimated remaining pump life) - 23.2%
Pretensioning pressure in reservoir - 73 Bar (72 - 102 Bar is optimal) (looks like the time to replace the accumulator is approaching)
Car is still down because I drained the coolant , pulled a vacuum in preparation to installing coolant, and a rubber hose failed where it connects to the heater valve. Took me over an hour to find the leak; to get to the heater valve the windshield wiper assembly must be removed. Broke the plastic cover under the wipers (and over the wiper assembly). $90 and waiting for it to arrive. I figure I'll go ahead and replace brake pads and rotors and bleed the hydraulics while I'm at it....
