2003 E55 Headers Question
I've read every thread on headers I can find, most of which seem to be dated and I'm trying to figure out what the current school of thought is for what to go with. The car is not a track car. Mostly the goal is to get some flow improvement over the stock headers since I have to do something for the leak and get some performance gain out of it. Eventually I figure I'll improve the cooling for the intercooler and put smaller supercharger pulley on and an ECU tune. The rest of the exhaust is in fine shape and I don't need to do a full on exhaust, so something that will attach with minimal fuss is preferred. But since I'm pulling it apart, more gain is more better. It seems like these days EuroCharged is the cheapest (around $600), XSP long tube for about $1k, and Kleeman shorty headers also around $1k. Then there are the more expensive options, which I probably am not going to consider because this is really more of a fun change rather than going towards a goal of an all-out racecar.
My thought is either EuroCharged or XSP. All three of them claim bolt-in, and it seems the long tube headers generally gain more although I've read some reports (perhaps on different long tubes?) that you have to hack up the rest of the exhaust if you put them on or there are other issues.
Any recommendations appreciated.
One thing that's really surprising is it didn't change the noise level much at all.
The AMG mufflers I put on made more of a sound difference than the headers.
I'll probably do a resonator delete and x-pipe install next to add a little more grunt to the V8 sound.
The sound is another point. My wife is the primary driver of this car, and she wants "more loud." So in that sense, that would make the long tubes a better option in that regard, especially if there's a bit more power gain to be had with them.
Curious if anyone's gone with the XSP long tube headers or Maximizer Long Tubes?
The point is that if I'm going to remove the exhaust, might as well do an upgrade.
I have EC mids and yes the fitment was good, had to hack off one small stud for the head shielding as it was rattling on full throttle. If you haven't already whilst doing the headers i would do motor mounts. will be a much easier job when the headers are out and they likely need to be done if they haven't been.
The plan is to do the motor mounts and transmission mount at the same time. They're all pretty shot and you can notice the drivetrain flopping around.
I'm debating whether to let the shop do it or do it myself. From what I can tell it looks like doing the headers and mounts should be no more than a weekend, potentially one day if I can actually get working on it without interruptions (which is unlikely). The estimate from the shop was fairly high, I think it was a "We don't want to do this job" quote. Have to decide.
https://www.ebay.com/itm/Maximizer-E...MAAOSw3ydV5Nbk
Everyone else was a lot more for these headers.
The pictures are too small to see the details but 1) it is a good practice to weld on the inside of the flange and 2) single piece flanges tend to lift due to heat causing leaks - individuals are much better. These headers lack both so I thought I’d mention it for future reference.
https://mbworld.org/forums/w211-amg/...ml#post7426171
