2006 E55 Lock change
Old Apr 18, 2018 | 07:33 PM
Bill99's Avatar
2006 E55 AMG
AMG wizards. Both of my keys do not work on the drivers door to auto unlock / lock. I looked in the forums but could not find anything. What is the possible issue and DIY to repair this?
Old Apr 18, 2018 | 07:58 PM
StarvingArtist's Avatar
CLS 55 AMG E500 ML320
New door handle.
Old Apr 18, 2018 | 08:35 PM
Bill99's Avatar
2006 E55 AMG
Yes a new door handle but how does this get matched to the frequency of the key fob and how do I change the valet key to fit the new lock or change the lock mechanism to fit the key? Also, I assume I need to remove the door panel, which I know how to do, after I do that does the new door handle get attached easily to the door skin?
Old Apr 18, 2018 | 09:29 PM
rapidoxidation's Avatar
2013 ML350 Bluetec
Does the key fob lock/unlock everything else (rear doors, passenger front door, trunk)?
Does the mechanical key still work in the driver's side door lock cylinder?
Old Apr 18, 2018 | 11:52 PM
Bill99's Avatar
2006 E55 AMG
The key fob works when you press the buttons and all doors open. When you approach the car the key fobs don't open the drivers door but does open all the other doors.The mechanical key does work in the lock.
Thoughts?
Old Apr 19, 2018 | 01:47 AM
Strigoi's Avatar
2001 E320 Wagon, 2006 LBZ Silverado, 2007 E63 (sold), 2001 E55 (sold)
Your car has the setup where you can just walk up to it when it's locked and the door will open if the key is in your pocket?
If so, you need a new door handle. I believe they're a few hundred and are a dealer only part.
Old Apr 19, 2018 | 08:07 AM
It's normally easy to change, no coding, no door panel, but it might be different on an SL.
Old Apr 19, 2018 | 08:28 AM
https://mbworld.org/forums/w211-amg/...ht=door+handle
Old Apr 19, 2018 | 09:41 AM
2013 ML350 Bluetec
If you're creative and careful you might be able to rebuild the microswitches built into the rubber backside of the door handle. Replacing the assembly would be easier though.
Old Apr 19, 2018 | 09:48 AM
Yuille36's Avatar
Veteran: Marine Corps
07 E63 AMG, 10 C63 AMG, 07 E63 Designo, 07 E350, 09 C300, 07 C230
Definitely a new door handle is needed as the sensor has obviously went bad.
Old Apr 19, 2018 | 03:57 PM
Bill99's Avatar
2006 E55 AMG
OK. How do you deal with the valet key. Can you change out the mechanism or do you need new valet keys and where do you get those?
