MOBIL 2 JET ENGINE OIL
Old 05-22-2018 | 06:52 PM
joachim1's Avatar
c230 Kompressor SC
WHERE CAN i BUY MOBIL 2 JET ENGINE OIL?
Old 05-22-2018 | 07:23 PM
larrypmyers's Avatar
Veteran: Air Force
16 GLC 19 Volvo XC40 06Corvette Z06
Try the Fixed Base Operator (FBO) at your local airport.
Old 05-22-2018 | 07:53 PM
SICAMG's Avatar
2005 e55 AMG
Ebay
Old 05-22-2018 | 10:50 PM
sjc246's Avatar
2005 E55 AMG, 2017 E400 Wagon, 2018 C350e hybrid
The best price I could find (online) was Sky Geek.
Old 05-23-2018 | 12:17 PM
e500slr's Avatar
2011 E63, 2013 CLS63
How is this related to AMGs....?
Old 05-23-2018 | 12:20 PM
6172crew's Avatar
Veteran: Marine Corp
E63 and GL450, ML350 bluetec
My guess is supercharger fluid.
Old 05-23-2018 | 01:36 PM
Yuille36's Avatar
07 E63 AMG, 10 C63 AMG, 07 E63 Designo, 07 E350, 09 C300, 07 C230
It is the oil that is used in the M113K supercharger for the E55, SL55, CL55 and so forth...
Old 05-23-2018 | 07:46 PM
Redwood415's Avatar
92 W124 500E, 93 W201 190E, 11 C207 E350, 05 W211 E55
Try your local MBZ dealer parts counter, im sure they can order for you?
Old 05-24-2018 | 06:05 PM
sjc246's Avatar
No. There is no recommended service interval, nor are there any MB sanctioned repairs that required draining the fluid. The dealer does not have it and will not order it. They can get fluid for some of their other superchargers, but not the m113k (it's a different fluid).
Old 05-24-2018 | 07:28 PM
FunkTron's Avatar
2006 CLS55
if you had a w211 AMG in the w211 section of the forum, you'd know.
Old 05-25-2018 | 10:27 AM
Veteran: Air Force
Several months back there was a lengthy thread on care and feeding of M-B superchargers.
Turns out there are two different superchargers, depending which car you have. And they use different lub oil.
Also it included diy about how to change supercharger oil.
Old 05-28-2018 | 08:43 AM
FCPEuro's Avatar
Former Vendor of MBWorld
Mercedes
Last two cans I bought were from SkyGeek. Fast shipping out of New York.
--Kyle
Old 05-31-2018 | 07:54 AM
MACEDON's Avatar
05 E55, 98 CLK320
better quesiton is where the **** do I get the syringe and tube needed to empty the charger? I'm too lazy to hop from store to store, I'd rather get that stuff online....
Old 05-31-2018 | 08:05 AM
Yuille36's Avatar
I would try Amazon, as they would most likely have the oil, syringe and tube.
Old 05-31-2018 | 06:51 PM
sjc246's Avatar
I used this product from Amazon: "Karlling 150ML Large Big Plastic Hydroponics Nutrient Measuring Syringe". It's a large syringe with measurements (in ml) and a long flexible tube. It makes the job quick and easy. Just be extra careful not to drop the plug for the supercharger and don't overfill it (measure how much fluid you take out and add that much; it does NOT get filled until it overflows out the hole and unless you take the supercharger off to thoroughly drain it, you will not get all of the fluid out so you can't fill it with any known capacity).
Old 05-31-2018 | 06:54 PM
FunkTron's Avatar
2006 CLS55
x2 on amazon
Old 06-01-2018 | 07:13 AM
StarvingArtist's Avatar
CLS 55 AMG E500 99 ML320
If you level the supercharger by jacking up the back end of the car, you can fill it to the plug. Worked for me. (twice)
Old 06-01-2018 | 08:13 AM
sjc246's Avatar
It may work but that's over full. This has been discussed here before at length. Even when level, the fluid should not be up to the fill plug. With it over full you risk it leaking out the shaft seal.
Old 06-01-2018 | 11:23 AM
MACEDON's Avatar
05 E55, 98 CLK320
Thank you so much man, I am gonna copy/paste that into amazon and order it. I already have the jet oil.
Aware on just replacing the amount I take out and the screw. Stupid how there's no replacement for it...
Old 06-01-2018 | 04:29 PM
FunkTron's Avatar
2006 CLS55
I believe it was determined to be a certain size. I've ordered 2 (in case i drop one).
I'll need to get home to get the info on threads and dimensions.
Old 06-02-2018 | 07:58 AM
Yeh, I know. I've read all the treads, built a supercharger out of pieces of two, had it apart again for some minor porting and painting. The plug looks like a reasonable fill level to me, like it was designed that way. Common sense also tells me It's not lifetime lubricated. At least not the life I'm hoping for! The risk of some oil leaking out is not the biggest gamble I've ever taken. After two years and many many miles I'm confident my SC has enough oil in it. Not enough is a real problem.
Old 06-02-2018 | 12:36 PM
Pmarino's Avatar
04 E55 AMG BLK/BLK(MyDD), 06 CLK 500 (wife's) 07 ML500, 2012 C300(son's)
Listen to the StarvingArtist The fill amount is 150ml, not enough lubrication anywhere is not a good thing
See post 91 in the link below
https://mbworld.org/forums/w211-amg/368922-diy-supercharger-oil-refilling-4.html
Old 06-02-2018 | 12:41 PM
Pmarino's Avatar
See section 4, 1a .... At least every 30,000mi
http://www.lysholm.us/pdf/008451v1.0...ers_Manual.pdf
Old 06-02-2018 | 02:54 PM
sjc246's Avatar
See post #19: https://mbworld.org/forums/w211-amg/...ml#post6928644
Too little oil is bad, but so is too much. The correct fill level is 150 ml, but you will probably not be putting this much in if you suck it out with a syringe (you won't get 100% of the oil out). If the oil is too high it will increase drag (at the speed supercharger gears run, that equates to a measurable amount of horsepower being lost). This also results in excessive oil temperature and foaming/aeration of the oil, which will significantly reduce the lubricating ability.
Also, keep in mind that this oil level is specified for the factory rpm and boost level (which many of us are exceeding). Some supercharger manufacturers actually recommend lowering the oil level when increasing boost (although I would stick with the specified 150ml in our applications). For example, Kenne Bell recommends lowering the oil level by up to 1/4" when running high boost (explaining that this will significantly reduce oil temperature and reduce power loss by 15HP at 18,000 rpm vs the normally specified level). They also state that overfilling is the most frequent cause of supercharger failure (due to the resulting heat). By my calculations, 15 horsepower is equivalent to over 7 space heaters on high (11,000 watts); you probably don't want all that heat in your supercharger oil (and that's at the normal recommended fill level, we're not even talking about over-filling).
(As far as too little oil, I wouldn't worry too much: as long as the gears are partially submerged, they should be well lubricated. If the fluid level is completely below the gears, you will definitely have problems, but that would take an egregious measuring error.)
While it's unlikely that you will notice much of a difference if slightly over-full or under-full, as long as you're going through the effort to change the fluid, you might as well do it right.
Old 06-02-2018 | 05:38 PM
Alright, you've convinced me. That all makes good sense. I'll drop my level a bit next time I'm on a maintenance kick. With the speed limits I don't get much chance to spin the SC. Sometimes I stop in the middle of the highway just to take off again!
Quick Reply: MOBIL 2 JET ENGINE OIL
