Mod fever! All suggestions helpful!!!
Kleeman Headers-full custom exhaust
c63 mufflers
Jerry Dyno tune
TCU tune
83 pulley
Cold Spark plugs
FTP Heat exchanger
TTM Intake scoops
Ic pump
Belt wrap kit
So, I am not sure where to go next with this, I live in SoCal so temperature is a factor I was thinking to add these (keep in mind it’s a daily)
VRP secondary heat exchanger
colder thermostat
please shoot some suggestions,
c63 mufflers
Jerry Dyno tune
TCU tune
83 pulley
Cold Spark plugs
FTP Heat exchanger
TTM Intake scoops
Ic pump
Belt wrap kit
colder thermostat
https://mbworld.org/forums/w211-amg/...-bolt-ons.html
2nd heat exchanger and splitting the cooling, adding a intake won’t help? Or just not worth the $
you add a trunk or bay tank. The only intake that will gain power is the Needswings DCAI. You’ll also pick up 1.5-2 psi in boost with that intake as well.
http://www.needswings.com/needswings...air-intake-kit
I would save my cash for a set of long tube headers. I have a set of maximizer long tubes. They work great. Allows more flow than the mids and in end result you gain more power while making the motor more efficient. The secondary heat exchanger will make a good difference in recovery time. It did on my car. I would get it. I wouldn’t split the cooling until
Check these out:
Weistec Trunk Ice Tank for E55
Weistec 180mm Modular Crank Pulley for E55
Check these out:
Check these out:
