Transmission Problems HELP!
Old Jun 16, 2018 | 05:53 PM
kyledeg4's Avatar
e55 AMG
Hello and thanks for looking. Ive got a transmission problem that has been an absolute nightmare to figure out. Early build 03/2004 E55, 116k Miles.
So, the issue is fir first 5 shifts after the car has been sitting overnight. I pull out of the garage and stop at the stop sign at the end of my road, but when I give it gas and ether it hesitates and pulls very slow (similar to a bog down/vibration) stalls or it will go and the 1-2 shift is ridiculous and I get a huge buck from the car. It feels like somebody clutch kicked a manual car. then the 2-3 shift is super hesitant. Almost like it gets stuck in between the gears and the 3-4 shift is the same. Accompanying this, if you get on the throttle to accelerate while you are cruising the car acts like you are in too high of a gear with too low of a speed and shudders, but this also goes away when warm. After the first few shifts and the transmission is warm its silky smooth and normal. I have performed a few different things trying to remedy this problem to no avail. Best part is NO CEL or TCU codes!
Things performed:
new crank sensor
Trans fluid changed 2x- Level is set correct @80*C dip stick level, temp verified temp w/Scan tool
New filter
Valve body cleaned and installed both Sonnax TCC Damper Valve and Sonnax Sleeves (suppossed to remedy this exact problem)
New conductor plate
New 13 pin
Wires are clean- no atf on ECU side or 13 Pin connector side
External trans cooler- At first considered this may be part of the problem, but I doubt that many people warm up their cars until their transmissions are 80*C plus before driving them, also it happened before the switch to the external cooler(in fear of future glycol contamination due to having the valeo rad)
Things Left to try/replace:
TCC Solenoid?- May replace this just as a shot in the dark, hard to find 722.6/nag1 TCC solenoid problems on the internet
Torque Converter?
Prior glycol contamination?
Need to find a star tool to relearn TCC/Adaptations-Currently using icarsoft MB2
Try going back to stock trans cooler
TCU problems?
Other Factors:
1st fluid change had nothing crazy come out of the pan-fluid not burnt- no crazy metal shavings- only thing in question would be prior glycol contamination.
Cleaning Valve body/sonnax kits only produced cleaner, firmer shifts after being warm- cold problems still exist
Possibly related to 72mm FSP?-Doubt it because it would happen w/ my 77 clutched also
Vaccum Leak?- doubtful, I resealed the charger/tb/bypass valve- new seals+small amount of rtv on them to prevent leakage
Thanks for looking, any input appreciated.
Old Jun 16, 2018 | 07:45 PM
PieRat's Avatar
CLS55
Think its your SC clutch engagement. Mine was gettig really bad(first of the day) rezt would be fine until it cooled. But then it went away after thrashing the car on the track for a day.. not much help i know but i have the 77..Are you experimenting using manual mode to troubleshoot that it is at gear change & not sc clutch engagement?
Sc clutch appears to engage at different times dependant on gear, pedal depression and revs. Light throttle 1st gear is around 3k revs for example and in second it seems to be low 2k revs.
Also when you are crusing often youll be in 5th gear at low speeds. When you punch it if you dont depress the pedal to push the button on the floor itll just roll out that gear and probably run high load for a bit. At least ive found this on my car.
Old Jun 16, 2018 | 07:46 PM
PieRat's Avatar
CLS55
Ah crap you have fsp most of what i said iz useless. Maybe its youse bpv doing stuff?
Old Jun 16, 2018 | 10:30 PM
gjunon's Avatar
04 E55 AMG
Manual mode
Are the symptoms occurring in comfort, manual, and sport models? Did you flush the transmission fluid, or drain it through the cooler line?
Old Jun 17, 2018 | 01:41 AM
kyledeg4's Avatar
e55 AMG
Thank you guys for the replies, yep I’m on FSP and this occourred with three different pulleys. Also it was drain through cooler line, no “flush” with the machine.
I am am not familiar with bpv, please explain?
Also, it does NOT occour in manual mode, only in C/S modes. Thanks again
Old Jun 17, 2018 | 11:51 PM
gjunon's Avatar
04 E55 AMG
If it does not occur in manual mode that would lead me to believe it is a problem with the TCU.
Did you have a tune done? Have you tried resetting the ECU by removing the battery cable?
If you are in the Southern California area you can use my star system.
Old Jun 18, 2018 | 12:17 PM
kyledeg4's Avatar
e55 AMG
Thank you for your input and the offer on the star usage, I lived in San Diego at one point but now I am in North Carolina. The TCU could be a possible culprit. I have re loaded my ECU tune a few times, as well as performing the sneaky reset for adaptations, along with the battery terminal trick, no dice yet. I had three different ECU tunes, two with a 77 clutched and then with my setup now 72 FSP. Symptoms were the same throughout every tune. I think torque converter is the next step because my transmission holds every gear with no slippage and performs normal at higher rpm(above 4K)
Old Jun 18, 2018 | 09:53 PM
gjunon's Avatar
04 E55 AMG
You can try swapping the TCU to see if it fixes your problem. If you know anyone in the area with an E55 it should be pretty painless to do...
https://mbworld.org/forums/w211-amg/...-swap-diy.html
Old Jun 19, 2018 | 11:55 AM
MACEDON's Avatar
05 E55, 98 CLK320
This almost smells like TC to me too
Old Jun 25, 2018 | 02:18 PM
kyledeg4's Avatar
e55 AMG
Same, Replaced the TCC solenoid with no change. UPD 3000 stall will be here on Wednesday I will let you guys know how it goes. I took the trans out today.
Old Jun 26, 2018 | 07:57 AM
MACEDON's Avatar
05 E55, 98 CLK320
Lettuce know how it goes, interested in finding out if it solves your issue. Did you have any vibration at high speeds? (90+ mph)
Old Jun 27, 2018 | 07:49 PM
KAMG's Avatar
2005 C55 AMG (sold), 2005 E55 AMG
I had a similar issue with the 722.6 with my C55. Jerking/bucking 1-2 shift, only when cold. Everything was smooth when the transmission warmed up. Replaced conductor plate, drained and filled transmission twice but no luck. Turned out to the the PWM solenoid
Old Jul 3, 2018 | 12:04 AM
kyledeg4's Avatar
e55 AMG
SOLVED
Ok guys, I know my way around a car. I know my way around a scanner and how to spot electrical/sensor problems on cars. How this was the problem.. don’t ask me because I could not tell you.
Symptoms described above have been going on for 3-4 months... more apparent as time went on and power was added, until yesterday. I was on my way home (after installing a new tq converter(definitely part of the lockup issue) upd 3k stall, which is amazing btw. Best bang for buck drives/shifts so much better) the lockup issue was solved but there was an underlying issue and the check engine light started blinking on/off, I had never seen this before. Looked at the codes.. multiple misfires on most/all cylinders while idling. No other codes.. NOTHING! Not even MB specific ones...
spent all day checking for vacuum leaks, put old MAP sensor back in, put old crank sensor back in, cleaned cam sensor, cleaned AIT sensor, put stock injectors back in, stock pulley back in.. even RTV sealed the surge tanks because that was the only gasket on the top end of the motor that I re used when I pulled the charger for a meth install and re-seal.. to no avail.. no vacuum leaks.
sitting, idling, misfiring, staring at my scan tool in 95* for 3 hours.... short term fuel trims would go insane trying to add 20-25% fuel every time the computer handed off the reins to let the sensors handle fueling stalling the motor or causing a rocking idle ... even pulling he surge tanks revealed a very heavy gas smell.
Only thing left was the 02 sensors to replace... I was reluctant because usually they show codes and 9/10 times they will be slow to report voltage or get stuck and you can usually watch this happen and easily diagnose a faulty O2 on the scan tool as well but these gave NO symptoms whatsoever. Finally broke down and bought two new upstream 02’s as I don’t like to buy parts without a solid reasoning .. threw them in. BAM.. no more intermittent rocking idle.. no more misfires.. no more hesitation when rolling into the throttle, just an appropriate downshift and pull. The thing that bothers me most, is that the new 02 sensors voltage is almost identical to the old ones, with a refresh rate that is just about the same(maybe a tad quicker).
This makes perfect sense to be the culprit if you think deeply about it, but I just cannot understand how the computer did not throw a code or they did not show their degradation of signal on a scan tool.
Maybe this needs to be a sticky, maybe someone more experienced would’ve seen this as the issue and thrown the parts at it (even though the 02 behavior was normal) before going towards the trans, but untill yesterday drivability had not been affected one bit, besides a slight hesitation to kick down while cruising and a cold shift issue.
Thank you all for your help MB World
P.S. if anybody buys the transgo shift kit, the main pressure valve is the incorrect size for our valve body. You can use the other parts from the kit, but do not use the main pressure valve. After the sonnax kits, transgo kit, new conductor plate, and UPD 3000 stall.. this car is a rocket that shifts fast like the SLR. I cannot wait to get a TCU time and see what it really does.
TLR Replace your 02 sensors even if they seem fine......
Old Jul 3, 2018 | 12:39 AM
gjunon's Avatar
04 E55 AMG
awesome that you tracked down the problem! Thank you for sharing it will help many!
Old Jul 3, 2018 | 10:52 AM
kyledeg4's Avatar
e55 AMG
i sure hope so!
Old Jul 3, 2018 | 12:28 PM
StarvingArtist's Avatar
CLS 55 AMG E500 ML320
Just a random thought, has anyone with the 82mm throttle body hiccup replaced seemingly good o2 sensors?
Old Jul 3, 2018 | 12:41 PM
kyledeg4's Avatar
e55 AMG
looks like we’re going to have to hunt someone down. It might work, although they get a CEL with them usually... worth a try though.
Old Jul 8, 2018 | 07:35 PM
kyledeg4's Avatar
e55 AMG
FWIW, one of my buddies here on the forums (guy I bought some parts from a few months ago) ... also had been having a weird hesitation between shifts issue. He replaced both upstream sensors... solved his issues too. Again, no codes.. no other indication.
Old Jul 9, 2018 | 03:17 AM
PieRat's Avatar
CLS55
Is it hesitation during all shifts or only light hrottle applications?
Old Jul 9, 2018 | 09:05 AM
kyledeg4's Avatar
e55 AMG
for me it was just light throttle or normal driving, my guess is(not familiar with how these ecu's handle open/closed loop fueling so dont quote me on this) because the car runs off of set maps when you get on it hard vs. aiming for a certain AFR while cruising/partial throttle.
Old Jul 9, 2018 | 12:08 PM
lseguy's Avatar
2005 c230
not too shocking. I had a random misfire/stumble issue (separate car, BMW 540) a year or so ago that I could not track down. No codes, wasnt vaccum leak, etc. Long story short: took a chance and replaced all 8 ignition coils. Solved the issue. Apparently at least 1 was marginal. Local shop told me (after the fact) that they had a special tool designed to test coils, and that tool most likely would have detected the issue. Owner said sometimes an ignition coil will be marginal..enough to cause detectable random stumble, but not enough to trigger a code.
