Sac Raceway in the E55
I figured I'd post here to get some feed back on my times and see what the "internet professionals" think about my times and experience.
This was the first time at the track with my 2005 E55 and my best time was a 12.428 at 112.65 mph. On Wednesday nights it's bracket style racing and I took home first place out of about 300 cars!!!
It was about 85 - 90 degrees out and the density altitude at sac raceway was 1668.74 ft.
The vehicle is on 19" federal street tires. It has a 77mm pulley, belt wrap kit, Carbonio carbon air box with tubes, split cooling system with BMW style res., PLM heat exchanger, Bosch 010 pump, Euro-charged ECU and TCU tune and 1 step colder NGK plugs.
Based off times I've seen online I feel this is slow. I was really hoping for high 11's. Is that un-realistic with my set up? I know I have a variety of factors working against me here (first time at the track in the E55, ****ty street tires, heat soak and restrictive exhaust)
What do you guys think? Should I have been faster? I think with an under the hood ice tank, cooler outside temps, more practice, better tires and long tube headers I should get into the 11's....
All constructive criticism is highly appreciated. Thanks and enjoy.
Winners Circle
Winning slip and fastest time. I ran 12.5 multiple times last night and my mph were 114.63. Thought it was weird I only trapped 112 on my fastest run.
My girlfriend and her friend. Little eye candy for you all.
You are correct though, I really need to be monitoring AFR's, IAT's, etc.
In fact, I just ordered a mass air flow sensor and data logger from VRP!!!
Then i will buy an under the hood ice tank (I don't like the idea of running a second pump or lines all the way to the trunk) and headers. Hopefully I will have this done buy late September so I can test again with cooler outside temps.
My plan is to install this data logger to get an idea on IAT's, buy and install and under the hood ice tank and re test mid to late September when it starts to cool down outside.
From what I've researched, with my mods, I should have been in the high 11's with around 117 trap speed....
How are you guys tracking these things? Comfort mode or Sport mode? Burn out or no burn out? What suspension setting? Etc.
oops yes, power train, if you hook it doesn’t matter esc on or off. I’ve always launched with it on.
