Quick Teaser on how my car looks
driffydre (07-24-2018)
Thanks! I just put a front window strip so it looks a bit more cooler in my opinion. But love how it turned out! Been nonstop working on the car. Now the steering wheel clicks from the blinker when I turn it to left then back to right. I will take it apart tomorrow, easy fix for sure. And my right windshield spassed out and stoped then my left beat the **** out of it so now the right is lose and not working. Probably easy fix 😂
They’re VOSSEN VFS2 they aren’t made for E55’s, but with my rarity of smarts I figured a way to make the suckers fit and don’t regret all the waiting! Just lowered the car literally 2 min ago! Pain in the *** for the rear, unbolted the drivers side axel
You have the stance perfected. Are you using lowering links? My car was lowered by Star but doesn't sit as low as your does. My only issue with going this low, is tearing up my carbon lip on every speed hump, I go over.
Many years ago, I got high sided on a speed hump. Very embarrassing
2010 E63 AMG, 2003 E500
Usually not a fan of tinted tail lights but yours look good and compliment the black paint. Have you considered upgrading to the facelift tails? I did and think it looks much cleaner without the red stripe in the middle.
oh I did it’s jist I had to put those back on. I bought them they looked awesome but had a short circuit Idk. top brake lights on them wouldn’t work. And three error codes showed
Were they the Depo ones from eBay seller fishcake? I had the same units and they worked great for about six months and then the same thing happened - top LED brake lights stopped working and error codes. I eventually found some used OEM ones on eBay for a good price and so far they've been perfect. Plug and play even though my car came from the factory with halogen tails. No coding required.
My car only sits that low after a couple of days when the suspension settles, but as soon as you start the car, it raises back to its correct ride height.
05 E55, 98 CLK320
Any wheels that look similar but will fit?
Those look very "Mercedes" like almost like they came stock with the car. I'm debating getting a fancy set once my car is mechanically superb (still playing catch up over here).
Damn that's the only raisin I can't stand spacers.
