Drivers Side Upper Lumbar Code/(leaking)
I also have a separate issue (which, based on reading, seems common?) where my auto close trunk wont close all the way when I press the red trunk close button on the lid. 90% of the time now it will begin to close, reach maybe halfway, then go back to open position. (As if something is blocking the lid from going down..but I've confirmed, nothing is blocking. If I repress the close button 3-5 times, it will usually then close. Alternatively, if I reach up and re-squeeze the manual open trunk lid lever above the license plate, I can briefly hear the vaccum motor whir, then if I touch the red trunk close button, usually the lid will then fully close. (but not 100% always).
My specific questions: Since the seat and the trunk lid use the same vaccum pump/system, is the fact that the drivers side lumbar is leaking, also causing the trunk close issue? Also, has anyone here replaced the lumbar bladder on a W211 E class? Not finding any writeups/youtube vids that are specific to the W211 Dynamic seats.
As for the trunk lid, it's not related. The trunk lid does not use vacuum or air pressure to operate (you're thinking of the w220 S-Class, which has a pneumatic trunk latch). The latches and actuator are all electric on the w211 (I'm assuming it's a sedan... if you have a wagon, the actuator is hydraulic).
As for the trunk lid, remove the panel on the left side of the trunk and inspect the linkage to the position sensor (a small sensor connected to the mechanism with a small plastic linkage, next to the main closing motor). Sometimes the linkage gets detached from the position sensor and causes this type of problem (it stops half way because it doesn't see any change in position so it knows something isn't right). If you have access to an SDS or high level scan tool, check for fault codes--they should point you in the right direction. You can also check the actual values for the position sensor to make sure it's working correctly (easier than removing the panel, if you have an SDS).
Either way, I'll continue searching more, and dig into the seat in a couple of weekends.
https://mbworld.org/forums/s-class-w...-run-down.html
Took some time but figured it out! Clipping off two little black zip ties allowed me to slowly and carefully pull the lumbar bladder ( and of course it’s felt and mesh covering) towards the left/drivers side of the seat and slowly wiggle and squeeze it out. Was even able to leave all airlines intact so that I did not risk breaking off any of the plastic nipples.
it looks like for some reason the thin mesh covering between the upper lumbar bladder and the backside of the seat itself wore through at a small point causing a cross shaped small crack in the bladder. Appears may be that small area of the vinyl bladder was actually just touching the rough black part of the seat causing a friction wear/crack. Now to find best way to repair. I’ll also insert another piece of cloth between bladder and seat when I reinstall
