7 hours of labor for valve cover gasket??????
Old Aug 29, 2018 | 05:23 PM
Ruffian.'s Avatar
W211 E55 AMG
Got a quote from an indy mechanic here in Chicago for valve cover gasket replacement at 7 hours of labor??? This seems awfully high.
What should i be paying labor wise for valve cover gasket job?
Old Aug 29, 2018 | 05:31 PM
05-E55's Avatar
2005 E55 AMG
On E55? That's crazy. I've watched it done by my Indy, maybe an hour or so if I remember right. I can look up the receipt if necessary. I'm no mechanic but I felt like I could've done it myself.
Old Aug 29, 2018 | 05:36 PM
hachiroku's Avatar
SPONSOR
2007 Mercedes E63 AMG
book time is never accurate for the W211. my indy said the book tells you to be VERY through and there are ways to do things faster safely. hopefully they are charging you for actual time logged not book time. otherwise go somewhere else. also if the mechanic goes on lunch during that time, it shouldn't count even if its under the book time.
__________________
-BARRY
​​​Follow us on instagram @eightysixtuned
https://www.eightysixtuned.com
Old Aug 29, 2018 | 05:49 PM
PieRat's Avatar
CLS55
2hr max
Old Aug 29, 2018 | 07:20 PM
Strigoi's Avatar
2001 E320 Wagon, 2006 LBZ Silverado, 2007 E63 (sold), 2001 E55 (sold)
Book time is bull**** a lot of the time.
My housemate recently replaced a window regulator in my W210. He said it took him 20 minutes. Book time was 1.8 hours and that's what his shop charges for the job.
Old Aug 29, 2018 | 08:32 PM
tw2's Avatar
tw2
I took about 3-4 hours getting every single atom of sealant off and very thorough cleaning and replacement of the hoses. I doubt any shop would be as conscientious as I was.
Old Aug 29, 2018 | 10:14 PM
gjunon's Avatar
04 E55 AMG
Took me around 5 hours to do both sides. It really isn't that hard to do.
Here is the DIY I made a while back when I did it. You should also change your plugs and wires if you have not done so when you do this job.
https://mbworld.org/forums/w211-amg/...periences.html
Old Aug 29, 2018 | 10:43 PM
patrick_y's Avatar
2006 E55 and 2002 E320
Independent mechanics screw people over too... I've seen BMW independents that cost as much as the dealer and I've heard of independents that cost more than the dealer for mostly equivalent work.
Usually the franchised dealer can get the part cheaper than the independent can due to higher volume. Unfortunately the dealer doesn't pass the savings onto the consumer.
Old Aug 29, 2018 | 10:48 PM
tw2's Avatar
tw2
I later learnt there is a product to dissolve all of the sealant which would have sped up the time I took considerably.
Old Aug 30, 2018 | 10:18 AM
turabaka's Avatar
2004 E55 AMG
I work as a service writer for an independent repair shop.
Went ahead and looked up the book time in the Mitchell labor guide. The job pays 2.7 hours to reseal both valve covers.
I have no idea where they got the 7 hour figure from.
