M156 Head bolt pics for Science (E63)
as far as the timing marks on the M156, you set the mark at 40, then check to make sure you’re timing tools fit the cams. If they don’t (you can be off slightly) then you turn the engine over 360 degrees and check again until the tool fits and your mark on the pulley is lined up like Tasos’s video. At that point you can start pulling the cams off and replacing the bolts. You’ll hit the torque value and add 270 degrees more of a turn. I’m glad someone took the time to make a video, and shared more info on the M156, they are cool engines but MB didn’t really beef them up until later, so the older ones need different oil, and possible head bolt replacement.
Every engine has its strengths & weaknesses and the M113K, while quite formidable, isn't perfect either. Doesn't stop me from enjoying & appreciating both engines thoroughly.
In terms of any commentary on here, I just try to keep things as objective as possible.
Going OT for a moment, did you upgrade injectors on your E55? Looking into this after an interesting conversation with Eurocharged the other day.
I have 69K miles currently. I bought a set of Bosch injectors for $150. And it will probably take under 2 hours for me to change them. I will post the video when I change them. FCP had them for the same price during the pandemic but recently raised their prices to 300+, so I bought from somewhere else.
This issue popped up after having my upper oil pan gasket replaced, they had to drop the entire engine subframe. We scanned this several weeks ago, and it pointed to this sensor, so my tech disconnected it and reconnected, and the problem seemed to go away, after the car was scanned. So it think that we may need to replace this sensor.
