New E55 owner dyno results!
Old Sep 30, 2018 | 02:15 AM
Lriver1004's Avatar
2012 CLS63
Originally Posted by tw2
Yes probably. All dyno's are a bit different so comparing different cars on different dyno's is never going to be accurate. Some stock cars hit 400whp on dyno dynamics. I would be more concerned about the torque curve, it looks like it drops off sharper in the higher rpm than most.
Do you think this could be because of how badly it is heat soaking?
Old Sep 30, 2018 | 02:17 AM
tw2's Avatar
tw2
Yes.
Old Oct 10, 2018 | 11:47 PM
Lriver1004's Avatar
2012 CLS63
Yes.
BTW when I installed the bosch 010 pump and took the car for a spin, boy did she wake up! I hit it and sport from a dead stop and had to let out cause it just kept boiling the tires. Before the pump my e500 would boil the tires more than my e55.
Old Oct 11, 2018 | 01:44 AM
tw2's Avatar
tw2
Awesome, glad you got it sorted. Amazing how much heat the supercharger can put out.
Old Oct 11, 2018 | 01:47 AM
PieRat's Avatar
CLS55
It makes so much heat it makes me want to go turbo! lol. But I want something that has better cooling to the brakes or weighs less than an AMG...
Old Oct 12, 2018 | 05:31 PM
WannaBeeAMG's Avatar
2005 E55 AMG White
Just for reference, this is what my car did on a Mustang dyno. It was a somewhat hot & humid day in IL. Outside Temp around 85*F IIRC. Best run was 404hp with WCF with more fans aimed better and IAT at the lowest, but the first pic was what we deemed the average to be as far as what it consistently could deliver. I didn't get a pic of the best dyno run at 404 but I have a printout somewhere and I know that was the number it put down on its best run. Again, completely Stock E55 other than a bit higher flow IC pump. This is on a 2WD mustang dyno, of which I'm told is Mustang's top model dyno. They've tuned close to 2000hp drag cars on it before so it's a serious setup. Hope that helps you! Also, as the others have said here.... Get That IC Pump In ASAP!
Stock 2005 E55 baseline dyno run on Mustang Dyno
2 more base line runs in stock trim on mustang Dyno
Old Oct 12, 2018 | 06:31 PM
  #32
Lriver1004's Avatar
2012 CLS63
Already have the bosch pump in. It made a ton of difference btw. The mustang dyno that Kyle car was on was a awd dyno. Not sure if that makes a difference. If I'm 40 whp off from your stock car then I may have some other issues...
Old Oct 17, 2018 | 11:58 AM
  #33
1FSTAMG's Avatar
C32 AMG - RIP :(
so go get it redyno'd with the new pump on now
Old Oct 17, 2018 | 02:58 PM
  #34
karpetcm's Avatar
2006 E55 AMG
I would get back on the dyno again and get a real baseline. You want a good running stock car for a baseline. I ran a 434 RWHP and 486 RWTQ with EC Tune, Muffler Delete and High Flow Filter not that the last 2 mods added any power. Once I get my BWK installed I will be going back on the dyno, I get too much belt slip.
Old Oct 17, 2018 | 04:05 PM
  #35
Lriver1004's Avatar
2012 CLS63
I'm thinking of going back once I get a set of headers.
Old Oct 17, 2018 | 04:07 PM
  #36
Lriver1004's Avatar
2012 CLS63
I shouldn't be far off. From what I've read my numbers are normal for a mustang dyno. It was also an AWD dyno but I'm not sure if that matters much. I'm going back to the dyno after headers and tune!
